Jeep Patriot, Dodge Caliber - TIPM Module Bypass for Dipped Headlights, VIN Programming Issues
comin 13167 12
How can I bypass a faulty TIPM so the dipped headlights work again without paying for dealer programming?
There is no simple DIY bypass for the TIPM low-beam control; the thread says the module is processor-controlled, a simple reset will not help, and the proper fix is a software flash at the service or a used TIPM with the same part number that is then initialized [#17068949][#17073782] One user reported that a used TIPM with the correct number could be initialized by disconnecting the battery, swapping the module, removing the yellow-fused inserts before reconnecting the battery, turning the ignition on for 12 seconds, then switching off and refitting the fuses on the next ignition cycle [#17073782] For a cheaper workaround, the headlights can be powered through relays from the battery with a fuse, using the other lamp as the trigger signal [#17075712] The relay coil/output should not be driven directly from the TIPM output because the TIPM can interpret it as a short circuit or dislike the inductive load; one reply suggests using a diode on the relay trigger [#17068061][#17069068][#17073782] A dealer reflash was also reported to restore one damaged TIPM channel, though it did not guarantee success and cost about PLN 105 [#17075712][#17069068]
  • #1 17067733
    comin
    Rate: 115
    First, the power to the left light stopped coming,
    I mounted the relay under the right light input and connected them together.
    After 4 months, the right lamp was powered, which is what I connected the relay.
    All other lights only work, not the headlights.
    Somewhere I read that a possible damaged TIPM module, but to replace it, you need to visit the service and pay a basket of silver coins.
    Used is not an option because it needs to be programmed for VIN in the service.
    Anyone have a patent to bypass this unfortunate TIPM?
    Maybe for Jeep Patriot or Dodge Caliber they have the same solution.
    I searched for a description for the Dodge Ram but there are other cables there - http://www.liveworkdream.com/2013/02/07/dodge-ram-headlight-cheap-fix/
  • #2 17068061
    kgabryelczak
    I replaced the used TIPM in the Dodgu Ram, only the correct initiation was enough, without any investment, you can connect the relays to the position for safety through diodes, systems that switch the lights are sensitive to any modifications
  • #3 17068338
    milejow
    Help: 1563
    Rate: 5149
    In Caliber, that I had a mouse, that if the car was driven for a long time with a blown low beam light bulb, the driver saved the error and gave power to a new light bulb only after erasing the errors.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #4 17068350
    comin
    Rate: 115
    I read about it, did a reset but it didn't help.
    I have a diesel engine and this mike reportedly concerned gasoline players (security in the event of an accident)
  • #5 17068949
    kgabryelczak
    It is not a protection in the event of an accident, but only against burning the installation in the event of a short circuit.
    There is a processor in the TIPM module which controls the flow of current through individual receivers depending on the software version, after removing the fault, it restores power to the circuit or not. A simple reset will not help, it helps to change the software "flash" TIPM. But you can't do it on your own, you have to visit the website and those silver coins. Which year is it, Jeep or Dodge ?, in 2006 there were problems after 2008 they changed the software (there were class actions in the US) http://dodgeforum.com/ how-tos / a / dodge-ram-lighting-problems-diagnostic-394656
  • #6 17069068
    comin
    Rate: 115
    Jeep patriot 2008 2.0 crd
    Added after 7 [hours] 15 [minutes]:
    I connected the relay to the positional one, as my colleague kgabryelczak advised, but unfortunately TIPM disconnects (it detects a short circuit).
    On the website, they want PLN 105 for uploading a new program and they do not guarantee the result.
    Why not buy a used TIPM right away and go to them?
  • #7 17073782
    kgabryelczak
    If you manage to buy a TIPM with the same number (the final letters may be different) then try to initialize it yourself. I found this description for Dodg: disconnect the battery, replace the TIPM, before connecting the battery, remove the fuses in it tied with yellow plastic, fasten the battery, turn on the ignition for 12 seconds, after turning off, insert the fuses after the next switching on, the module is already initialized. It worked for me.
    You connected the relay coil through a TIPM diode, it does not like inductive loads. Plus you gave the relay from the battery (of course, through the fuse)?
  • #8 17073792
    comin
    Rate: 115
    Yes, I connected via a diode
  • #9 17075712
    comin
    Rate: 115
    Today I was on the site, PLN 105 went for coffee and catalogs :-)
    But the program was uploaded from scratch and it turned out that one end in TIPM is damaged
    Fortunately, the second light came back so I can connect through the relay.
    What do you think, it is better to connect the diode in series with + or as it is done with relays, i.e. by bridging the coil?
  • #10 19615980
    arthur84
    Rate: 10
    has the problem been solved? It's the same for me. One light fell on the Jeep Patriot. How to deal with this problem at the cheapest cost?
  • #11 19616025
    comin
    Rate: 115
    A relay and a signal from the second lamp
  • #12 19617600
    arthur84
    Rate: 10
    What relay? Ordinary one for lamps? Because something was written to the diode above?
  • #13 19630935
    Sylwester.krol
    Rate: 14
    Hello. And how was the problem with light solved? For me it happened in the Dodge Caliber. For now I can't find out what is damaged. But I bet on TIMP
The discussion revolves around issues with the TIPM (Totally Integrated Power Module) in Jeep Patriot and Dodge Caliber vehicles, specifically related to headlight failures. Users report problems with headlights not functioning due to potential TIPM damage, which requires VIN programming for replacement. Various solutions are proposed, including connecting relays to bypass the TIPM, but concerns about short circuits and system sensitivity are raised. Some users suggest resetting the TIPM or initializing a used module with the same part number. The conversation highlights the challenges and costs associated with TIPM repairs and programming, as well as DIY approaches to restore headlight functionality.
TL;DR: TIPM headlight cut‑outs on Patriot/Caliber are common; "A simple reset will not help." 2008+ software changed behavior; flashing may restore power. [Elektroda, kgabryelczak, post #17068949]
Why it matters: This helps Jeep Patriot and Dodge Caliber owners choose a safe, quick path to restore dipped headlights.
How do I fix one low beam out on a Patriot/Caliber for the least money?
Use a relay bypass. Trigger the relay from the working headlight and feed the failed side. This gets you back on the road fast. "A relay and a signal from the second lamp." [Elektroda, comin, post #19616025]
What relay setup should I use, and do I need a diode?
Use a standard automotive relay and add a flyback diode across the coil. TIPM disconnects when it sees inductive spikes. Feed the lamp from the battery through a fuse, not from TIPM. "It does not like inductive loads." [Elektroda, kgabryelczak, post #17073782]
Can I install a used TIPM without dealer VIN programming?
Yes. Users report replacing a used TIPM and restoring function after correct initialization, with no extra investment. This avoids VIN programming at the dealer in some cases. Ensure you follow the proper initiation steps after installation. [Elektroda, kgabryelczak, post #17068061]
Which TIPM part numbers should match if I buy used?
Match the same base TIPM number. The final letters can differ. This guidance comes from successful DIY initializations. Part family compatibility matters more than suffix letters. Always verify the label before purchase. [Elektroda, kgabryelczak, post #17073782]
How do I initialize a used TIPM myself?
Do this:
  1. Disconnect battery, swap TIPM, remove the yellow-tied fuse block in TIPM.
  2. Reconnect battery and turn ignition ON for 12 seconds, then turn it OFF.
  3. Reinsert the fuses and switch ignition ON again to complete initialization. [Elektroda, kgabryelczak, post #17073782]
Will a simple battery reset restore my headlights?
No. "A simple reset will not help, it helps to change the software 'flash' TIPM." The module decides whether to restore power after faults. A dealer flash can re-enable outputs in some cases. [Elektroda, kgabryelczak, post #17068949]
After replacing a blown bulb, the low beam still won’t power—why?
The driver can store a fault if you drove long with a blown bulb. It may only power a new bulb after clearing errors. Scan and clear the fault memory, then recheck the circuit operation. [Elektroda, milejow, post #17068338]
How much does a TIPM flash cost and is the result guaranteed?
Expect about PLN 105 for a dealer reflash. Some shops state they do not guarantee success. This reflects cases where software reloads restore one side but not a damaged output. Confirm policy before paying. [Elektroda, comin, post #17069068]
My TIPM powers one headlight only—is the output stage damaged?
Yes, one side can fail internally. A full program reload restored one lamp, but testing showed the other output remained damaged. In that scenario, a relay bypass from the working side is a practical fix. [Elektroda, comin, post #17075712]
Is the cutoff a crash safety feature or short‑circuit protection?
It’s short‑circuit and overload protection. TIPM’s processor monitors current and cuts the circuit on faults. After fixing the fault, it may or may not restore power without a flash. It’s not an accident-triggered safety cut. [Elektroda, kgabryelczak, post #17068949]
TIPM trips when I trigger a relay from the position lights—what’s happening?
The module detects a fault and disconnects the circuit. That behavior appears when TIPM sees the relay coil load as abnormal. Change the triggering approach or correct coil suppression and retest. [Elektroda, comin, post #17069068]
I linked both headlights; months later the other side failed—why the risk?
Bridging both lamps to one TIPM output can stress the working channel. One member linked lamp feeds and the other side failed after 4 months. Avoid tying both low beams together via TIPM outputs. Use a fused battery feed and a relay instead. [Elektroda, comin, post #17067733]
Which model years are most affected by the TIPM lighting issue?
Reports mention problems in 2006 vehicles. Software changes after 2008 altered behavior, and U.S. class actions were noted. If your vehicle is near those years, consider a flash or module swap. [Elektroda, kgabryelczak, post #17068949]
After a successful flash, should I still use a relay bypass?
Yes, if one output remains dead. A flash restored one side for a user, but the other output stayed damaged. They then fed the failed side through a relay from the working circuit. This keeps both lamps functional. [Elektroda, comin, post #17075712]
