Mazda 3 BK 2004 - Self-Leveling Xenon Headlight Issues & Temporary Loss of All Lights
Manniek66 8784 2
  • Intermittent dipped beam and total lighting loss
    #1 17347640
    Manniek66
    Hi, I have a problem with the lights on the 2004 3BK self leveling xenon. What is the fault? The problem mainly affects the dipped headlights, once the right one is lit, once the left one, sometimes two but most often they do not turn on at all. Recently, there is one more piece of the puzzle - the momentary complete absence of all the lights. There is power to the fuses, you can hear the relays closing. What could it be?
    In summary, no dipped headlights (lights are working properly). There are high beam, brake lights, rear lights, front / rear fog lights. Sometimes it happens that all the lights disappear, including the controls on the cockpit.
    I am enclosing a diagram of the installation of lights in this car, unfortunately I cannot read it: /
    https://obrazki.elektroda.pl/2456954800_1411496019.png
    best regards
    Bartek.
  • #2 17348190
    piotrekwoj1
    Help: 947
    Rate: 3437
    But what's the problem? You need to check where they are dying, you turn on the lights and check everything for a generation.
  • Check xenon converter input voltage and wiring
    #3 17348307
    brylant238
    Rate: 44
    best regards
    Bartek.
    Jeedyne, what can you check what is happening with the input voltage on xenon converters. And it's best to take the car to an electrician, because the xenon systems have very high voltage. If you do not have basic knowledge, you can hurt yourself.
