[Solved] Troubleshooting VDO Tachograph: Driver Card Removal Error 34
bartosz.tarnowski 60354 3
  • #1 17070250
    bartosz.tarnowski
    Help: 26
    Rate: 30
    I checked the faulty VDO tachograph and put the driver card in it.
    The card reads and accepts, prints reports, etc.
    But I can not take out the card, I am reporting error 34 not possible.
    How to deal with this?
    kisiol
    Help: 36
    Rate: 469
    You have to undress the tachograph and manually rotate the mechanism. It does not take out force. The card is held with the teeth, the force exit will destroy the card
  • #3 17215188
    bartosz.tarnowski
    Help: 26
    Rate: 30
    The solution: after removing the bottom cover you gain access to the mechanism receiving and handing over the card, you can manually use a pen to spin the gear and drive the mechanism and recover the card
  • #4 17218587
    gulson
    System Administrator
    Help: 150
    Rate: 6121
    Report: The subject is closed and thus prevents the appendage of quite an important remark that any interference in the interior of the digital tachograph (eg breaking the manufacturer's seals to remove the blocked card) causes its irreversible destruction. Such a tachograph may no longer be used to record driver's working time and must be exchanged for another one!
