[Solved] HTC One M9: How to Install Polish Language on Scandinavia Model? Missing Language Options
wertiko7 4431 7
  • #1 17070803
    wertiko7
    Rate: 100
    Hello, I recently bought a HTC m9 used in Scandinavia, but after turning it on, it turned out that there is no Polish language, there are only 4 others. What are the ways to install the Polish language on this HTC one m9. I am asking for advice and any help related to it. Greetings.
  • #2 17070820
    mobista
    Help: 257
    Rate: 365
    The best way to upload the full Polish software is to go to the nearest good GSM service in your area and ask for a CID change and possible software update.
  • #3 17070828
    wertiko7
    Rate: 100
    There is no simple home remedy?
  • #4 17070837
    mobista
    Help: 257
    Rate: 365
    Probably not.
  • #5 17071332
    .:aspire:.
    Help: 53
    Rate: 62
    Insert Polish sim card and do factory reset. It is possible that the PL language will pop in.
    Another way is to do the s-off, then change the CID to HTC__032
  • #6 17074212
    br501
    Help: 14
    Rate: 56
    In most HTCs, you just need to upload morelocale2 applications and choose Polish. It should work.
  • #7 17078729
    taube
    Help: 5
    Rate: 8
    Use this simple program from the attachment. Only after each reset will Polish disappear.
    • ANDROID language enabler.rar (12.89 MB) You must be logged in to download this attachment.
  • #8 17082105
    wertiko7
    Rate: 100
    Thanks for your help, it helped and it works.
The discussion revolves around installing the Polish language on a HTC One M9 model purchased in Scandinavia, which lacks this language option. Users suggest several methods: visiting a GSM service for a CID change and software update, inserting a Polish SIM card followed by a factory reset, or using the MoreLocale2 application to enable Polish language support. Another option mentioned is using a specific program that requires reapplication after each reset. The author confirms that the provided solutions were effective.
