Alcatel One Touch 5022D: Adding Polish Language and Enabling USB Debugging - Android 5.1
Kamis47 4965 2
  • USB debugging enabled but phone undetected by language app
    #1 16201996
    Kamis47
    Rate: 43
    Hello, I have a new Alcatel one touch model 5022D with Android 5.1. Telephone bought abroad and it doesn't have Polish language. I found the Local & Language application, which polishes most, however, it requires USB debugging and permission to be enabled, more at http://blog.whenair.com/?p=204
    I managed to enable debugging, but the program can't see the phone. I have already tried to change the USB settings from MTP to mass storage and to no avail. Do you need any drivers? Is this a good way to crack or is it better to change all the soft?
  • #2 16202048
    actin
    Help: 187
    Rate: 799
    It's probably better to upload soft.
    You will have everything polonized because there, knowing life will be half or even less and probably with mistakes.
  • #3 16782913
    labik
    Rate: 79
    Do you have somewhere link to the software with Polish Lang ??
