Renault Master 2.5 dci 150 cars - Need for reversing beam pattern
piotras.plock 27489 16
How can I restore the reversing lights on a Renault Master 2.5 dCi 150 with an automated gearbox by adding a microswitch when there is no reverse gear sensor in the gearbox?
Use relay 602 for the reversing lamps and switch its control from the gearbox module, because the reverse signal is minus-controlled there [#17075663][#20278294] The thread’s working fix was to mount a microswitch on the gear lever and wire it into the reversing-light circuit so it closes the circuit only in reverse; the OP reported success after connecting one microswitch terminal to relay socket contact 30 and the other to fuse F5 [#17094323] It was also advised to keep the relay in the circuit instead of feeding the lamps directly, because the reversing lights draw about 3 A and the microswitch is only rated at 5 A [#17096320]
  • #1 17075384
    piotras.plock
    Rate: 14
    Hi. I badly need a reversing / reverse beam pattern for the Master 2.5 dci 150 2007 with automatic / automated quickshift transmission.
    The problem is that someone was doing a manual insert and the reversing lights are on all the time. At the moment, to avoid dazzling drivers behind me, I put a film under the bulbs in the lamps to cut off their power. However, I would like to bring this to order and "cut" the reversing lamp circuit by introducing a microswitch in the line, placing it next to the gear shift knob so that when throwing the reverse gear closes the circuit and thus restores the functionality of the reversing lamps.
    Has anyone already done a similar conversion?
    Anticipating the questions and suggestions - there is no reverse gear sensor in the gearbox, because the automated quickshift transmits a signal to the computer and this activates the reversing light, and in the gearbox housing there is not even room for the above sensor.
    Thank you in advance and best regards.
  • #2 17075483
    milejow
    Help: 1563
    Rate: 5149
    What kind of chest does this Master finally have because at the beginning you write about changing to manual and then that you don't have room for the sensor?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #3 17075528
    piotras.plock
    Rate: 14
    The automated box was. The housing and the whole "bottom" of the chest remained. Hence the lack of space for the sensor. The gear shifting robot has been disassembled, the manual shift cables and jack are added.
    genek1000
    Help: 289
    Rate: 1057
    602 relay for reversing lights - triggered by minus.
    It seems to me that the perfect place to apply your idea :D
    Master prz...a bvr6.pdf (105.29 kB)You must be logged in to download this attachment.
  • #5 17075684
    piotras.plock
    Rate: 14
    I would say "God bless you" but I will not be ruled by someone's money ;)
    How can I repay?
    genek1000
    Help: 289
    Rate: 1057
    Click "helped" or just thank you :wink:
    But not just now how it actually is there :D
    If he's not there :crazyeyes: (which I don't really believe :) ) let me know, we will look for something else
  • #7 17075741
    piotras.plock
    Rate: 14
    I clicked the paw straight away. I will let you know if the topic was resolved after Sunday, because where I live I will not buy a microswitch tomorrow to apply this patent.
    When I do, I will boast of photos, because I already have a plan how to do it. Will be for posterity.
    Once again lovely thanks.
  • Reverse lights still dead after relay removal test
    #8 17084288
    piotras.plock
    Rate: 14
    And I was happy too quickly.
    It turns out that after removing the foil pads from under the reversing light bulbs, they do not light up. There is therefore no way to check whether this relay actually has to do with these lights. Pulling out this relay does not cause any noticeable reaction in the vehicle.
    I also saw in the list that I got here that there is the phrase "except for the bus version". Poorly. Well, my car is a bus, i.e. a fully glazed version with seating for nine people.
    I looked under the hood to see if something was hanging loosely, but I only encountered the "robot" plug from the gearbox unsealed and foil-covered, which is rather normal when there is nothing to connect with.
    I will attach a photo of how the "box" with relays under the steering wheel looks like. Maybe it will give a clue.
    I am very puzzled by the fact that before the reversing lights were steady and now they are not at all. New bulbs. Other bulbs glow correctly.
    Diagnostic checks for reversing light relay voltage
    #9 17085323
    genek1000
    Help: 289
    Rate: 1057
    piotras.plock wrote:
    there is the phrase 'except for the bus version'. Poorly.
    No difference, bus or ordinary. The relay is always in the same place. The bus only has more relays.
    when the foil pads are pulled out from under the bulbs of the reversing lamps, they do not light up
    Now you have to tell us what's going on in the car in the sense where there is electricity and where it is not.
    In the attachment you have the diagram.
    Is the voltage at the relay's working contact? How do you close the work contacts does the reversing light come on? Cofania ma...r bvr6.PDF (24.75 kB)You must be logged in to download this attachment.
  • Checking relay 602 and reversing light control pinout
    #10 17085513
    piotras.plock
    Rate: 14
    I look according to 2008.05.23_NT8430eu_Visu v5.0_Renault Master X70
    According to the scheme from this NT, it comes out a little different (file attached).
    Relay 602 on board 1325, with the output for the rear lamps (172,173), fuse box (1016) and through the R320 connector to (119 ELECTRIC CONTROL MODULE OF THE AUTOMATIC TRANSMISSION).
    So at the beginning I have to check in the above-mentioned 5GW pin connector (REVERSING LIGHT RELAY CONTROL).
    I'm wondering if sometimes I completely ignore this system and just give power to the 602 relay indirectly through the microswitch which I bought skipping the line behind it towards the engine compartment ...
    Unbelievable how much knowledge can be learned in one evening.
    • 0126_A3.PDF (23.56 KB) You must be logged in to download this attachment.
  • #11 17086010
    genek1000
    Help: 289
    Rate: 1057
    And I look and see no difference between these diagrams when it comes to power connections, relay control and lamp connections :D
  • #12 17086019
    piotras.plock
    Rate: 14
    Naturally :) The difference is only in "drawing it out".
    Anyway, I am happy that I was able to understand anything from the scheme, although I finished school in 2000 as an electrician and until now I had no contact with the profession :D
    As soon as the weather allows, I will get on with it and solve it in the previously assumed way, that is, powering the relay from "plus after ignition", bypassing the section under the hood.
  • #13 17094323
    piotras.plock
    Rate: 14
    So today is an immortal moment :D
    This is the gear lever in the original:
    Here's how to prepare the lever for modification:
    Microswitch 5A and mounting screws, which I slightly shortened "to size":
    I applied the microswitch to the target mounting location, marked and made the holes for the screws:
    I connected the cable in such a way that one pin in the microswitch was connected to contact number 30 in the place of the relay, which we remove permanently:
    ... and the other directly under fuse F5 in the fuse box:
    Reversing lamp supply circuit open / gearshift lever "one":
    Closed circuit / lever in reverse position:
    With the ignition on, this gives the following effect:
    So everything works as it should.
    Once again, thank you very much for helping me solve this problem.
    Greetings Piotr.
  • #14 17096320
    genek1000
    Help: 289
    Rate: 1057
    And that's great. :D
    Electrical connections to patch because it smells of junkiness :cry: and personally I would not get rid of the relay.
    Although you write that the microswitch has a load capacity of 5A but are you sure for 12-14V?
    Even if it had such a load capacity for 12-14v, the current consumed by the lights is about 3A, I would leave this relay anyway.
    That's my opinion :D
  • #15 17096356
    piotras.plock
    Rate: 14
    I probably will. I just need to get some fuse and relay adapter.
    The pin in the relay is connected well. Soldered and insulated with a "insert" shrink tube, it is also rigid, without play. The microswitch cable is also soldered and insulated with a heat shrink. Only "under" the fuse, because I did not have an adapter, and I hate cutting and rummaging in factory installations.
  • #16 20277348
    JohnNeo
    Rate: 37
    Let me refresh the topic a bit.
    Where exactly does the control of the discussed relay come from? From the computer of this chest? Where to find the beginning of this signal?
    Regards.
    milejow
    Help: 1563
    Rate: 5149
    Mass control from the gearbox module
    Działalność własna
The discussion revolves around the need for a reversing beam pattern for a 2007 Renault Master 2.5 dci 150 with automated quickshift transmission. The original issue arose from a manual modification that caused the reversing lights to remain on continuously. The user seeks to implement a microswitch solution to restore proper functionality by cutting the reversing lamp circuit when the reverse gear is engaged. Various responses provide insights into relay configurations, wiring diagrams, and troubleshooting steps, including the use of a 602 relay for reversing lights. The user plans to bypass the existing system by directly powering the relay through the microswitch, while others suggest retaining the relay for safety. The conversation highlights the complexities of the vehicle's electrical system, particularly regarding the automated transmission's lack of a traditional reverse gear sensor.
TL;DR: "the current consumed by the lights is about 3A"—keep a relay in the reverse‑light circuit when fixing Renault Master Quickshift‑to‑manual swaps. [Elektroda, genek1000, post #17096320]
Why it matters: This helps Renault Master X70 owners restore safe, legal reversing lights without a gearbox switch.
Where does the Renault Master 2.5 dCi reverse‑light signal come from?
The reverse‑light relay is controlled on the ground side by the gearbox module. As one expert put it: "Mass control from the gearbox module." That means the relay coil sees a switched ground rather than a switched positive. If this control path is missing after modifications, the relay will not operate. Confirm ground control at the relay coil before changing wiring. This architecture is key for Quickshift‑equipped Masters. [Elektroda, milejow, post #20278294]
Why is there no reverse switch on Quickshift gearboxes after a manual swap?
Quickshift gearboxes do not have a threaded port for a mechanical reverse switch. The system uses the transmission control and ECU to command the reversing lamps. After converting to manual, there is no factory place to add a switch in the housing. That is why owners add an external microswitch at the shifter to recreate the signal. This avoids opening the gearbox or machining the case. [Elektroda, piotras.plock, post #17075384]
Where is relay 602, and does the nine‑seat bus version differ?
Relay 602 sits in the same under‑dash fuse/relay box location for both cargo and bus versions. The bus configuration simply contains more relays overall. Wiring for the reverse‑light relay location does not change between these variants. If you cannot find it, remove the panel under the steering wheel and inspect the relay carrier. [Elektroda, genek1000, post #17085323]
How can I restore reverse lights with a gear‑lever microswitch?
Use a shifter‑mounted microswitch that closes only in reverse.
  1. Mount a 5 A microswitch on the shifter so reverse closes the contacts.
  2. Run one wire to contact 30 at the removed reverse‑relay socket.
  3. Run the other wire to a fused feed under fuse F5, then test with ignition on. This provides a clean, driver‑actuated signal for the lamps. [Elektroda, piotras.plock, post #17094323]
Which contact and fuse points worked in the documented retrofit?
One lead from the microswitch was tied into contact 30 at the reverse‑relay position. The other lead was connected to a fused supply under fuse F5 in the cabin fuse box. With ignition on, selecting reverse closed the microswitch and lit the reverse lamps. This approach avoided cutting factory engine‑bay wiring. [Elektroda, piotras.plock, post #17094323]
Should I keep the relay if my microswitch is rated 5 A?
Yes. Even with a 5 A switch, keep the relay to handle lamp current and switching spikes. Automotive voltage is about 12–14 V, and "the current consumed by the lights is about 3A." Using the relay reduces wear on the microswitch and maintains proper circuit isolation. It also eases future service and upgrades. [Elektroda, genek1000, post #17096320]
What current do the Renault Master reverse lights draw?
About 3 A for the pair. Size wiring, switch contacts, and fusing with that load in mind. This figure supports the recommendation to retain a relay, even if a microswitch controls the circuit. It also helps diagnose voltage drop or dimming issues caused by undersized components. [Elektroda, genek1000, post #17096320]
What if my reverse lights never come on and pulling relay 602 changes nothing?
Test power at the relay’s working (load) contact first. If there is no voltage, trace the feed and fuses. Bridge the relay’s working contacts to see if the lamps light. If bridging works, the coil control is missing. Then check the ground‑side control from the gearbox module and related connectors. [Elektroda, genek1000, post #17085323]
Why did my reverse lights stay on constantly after the manual conversion?
The ECU originally drove the lamps without a mechanical switch. After a manual swap, that control can be stuck or misinterpreted, keeping lamps on. Adding a shifter microswitch lets you cut the original path and restore proper on‑demand operation. This avoids dazzling drivers and meets road rules. [Elektroda, piotras.plock, post #17075384]
Can I feed the reverse‑light relay from ignition locally and bypass the engine bay?
Yes. One documented approach is powering the relay from an ignition‑switched positive inside the cabin. This bypasses the under‑hood section and simplifies wiring after a manual conversion. Ensure proper fusing and maintain relay use for current handling. Verify function before final assembly. [Elektroda, piotras.plock, post #17086019]
Which factory diagram identifiers should I check when tracing this circuit?
Look for relay 602 on board 1325. Rear lamps are 172 and 173, and the cabin fuse box is 1016. The control path goes through connector R320 to unit 119 (automatic transmission control). Probe the 5GW pin labeled Reverse Light Relay Control when diagnosing. [Elektroda, piotras.plock, post #17085513]
Are the reverse‑light relay triggers positive or negative on this model?
They are negative (ground) triggers. As noted, the reverse‑light relay is "triggered by minus." Expect the module to sink current to energize the coil. Use this when choosing how to interface a shifter microswitch or testing with a multimeter. [Elektroda, genek1000, post #17075663]
