Choosing between 128GB ADATA SU800, ADATA Premier Pro SP920, or Goodram Iridium Gen2 SSDs
grzechupluta 3747 15
Which SSD should I buy for a system drive within 200–250 PLN, and is a 120/128GB model sufficient or should I choose a larger capacity?
Choose a 240–256GB SSD if possible; with expected occupancy above 50%, the larger capacity is preferable to avoid replacing the drive soon and to preserve better performance [#17048787] [#17052113] Among the listed options, the ADATA SP920 and Goodram Iridium Gen2 are both good for normal use: the SP920 has a good controller, good memory, and a five-year warranty, while the Iridium Gen2 has a theoretically weaker controller but performs adequately in everyday workloads [#17049886] If limited to 120/128GB, the Iridium Gen2 remains a reasonable choice, but the SP920 is also a strong option if its price and warranty matter more. The Crucial BX300 120GB was also reported as an MLC-based alternative available for about 199 PLN [#17049886] SSD benchmarks should include both sequential transfers and demanding small-file/4KB workloads, since copying one large file alone is not representative [#17050661]
  • #1 17048453
    grzechupluta
    I am trying to buy a ssd rather 128gb up to 200 zlotys max 250 as there will be a better system with small programs takes 30 gb, the rest about 40 gb so i think 128 is enough.
    I thought about
    Adata su800 3 years in PLN 190 as recently as the premiere of the 3D dice nand tlc
    Adata premier pro sp920 5 years gw 230 PLN has bones mlc and 5 years gw but is probably older than su800
    Goodram iridium gen2 120gb bones mlc 225 PLN
    So which one to choose, I know that the memory controller also counts and I do not know it at all.
    Or maybe there is another one at this price that will be good.
    Thank you in advance for your answer.
  • #2 17048787
    atomic99
    Help: 171
    Rate: 338
    Take [GoodRam Iridium], but I advise you to choose the 240GB version, so that you don't wake up with your hand in the proverbial potty and spit on your chin in a few months.
    I already had a few customers who were eager to save, and in a few months they bought 240GB, which was associated with a reinstallation of the system and an additional cost.
    So buy bigger once and don't waste 2 times.
  • #3 17049666
    grzechupluta
    Well, I do not have enough money to buy 256gb which costs about 390 PLN. I was planning to buy 128 if it won't fit, I will have a hdd and in the future I would like to buy a second ssd and crash the hdd.
    Has anyone else any suggestions?
  • Crucial BX300 recommendation and Iridium Gen2 benchmarks
    #4 17049886
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    Iridium Gen2, despite theoretically weak controller, can cope with standard use. The SP920 has a good controller, good memories, unfortunately a bit slower write speed, but it's also a very good hard drive, plus a 5-year warranty.
    When it comes to cheap, today I bought a Crucial BX300, apparently on MLC bones, I paid PLN 199 for the 120GB version (in total I found it only in X-com, maybe it will be cheaper somewhere). When I have a moment, I will test how it works and show off the results.
    Here the IRDM GEN2 benchmarks, unfortunately I only had 240GB, but for comparison, a colleague from the Forum also threw a measurement from the 120: https://www.elektroda.pl/rtvforum/topic3416340.html
  • #6 17050365
    grzechupluta
    This was the answer I wanted
    So it turns out that the su800 can be unloaded and think about sp930 and goodram irdm 2gen. How do you test the crucial, let me know :)
  • #8 17050640
    grzechupluta
    I wanted to write sp920 spelling, but in fact, how do these disks work in the sense that you have checked how long it takes to send a file, for example?
  • Small-file performance matters more than sequential speed
    #9 17050661
    dt1
    Help: 7319
    Rate: 8299
    I checked, but uploading one file is a poor test. In general, the tests you see results from simulate many scenarios. Sequential read / write is working on one large file. Working with small 4kB files is more demanding for the disk and different scenarios are visible in the form of different results.
    When choosing a disk, I rather focus on how it will work in not very ideal conditions, i.e. work with a large number of smaller files - because each SSD will handle relatively well with large continuous files.
  • #10 17050730
    grzechupluta
    Which of these discs would you recommend rather on mlc dice? that is, the adata su800 would fall off and I would like to have at least 70 gb of files on this disk with the system I think up to a maximum of 85 gb. Will the efficiency drop significantly when it is full enough? Or maybe cruciala
  • #11 17052113
    dt1
    Help: 7319
    Rate: 8299
    In total, assuming an occupancy of over 50%, I would rather target 240-256GB models. Each of the models listed on the MLC has its own advantages and disadvantages, and with normal use, they all work well.
  • #12 17052745
    grzechupluta
    there is still a disk on m.2 I found xpg sx6000 pci express 3.0 x2 and I have an asrock h110m pci express 2.0 x2 disc, will the twn disk not fold at all or will it work slower?
  • #13 17054412
    dt1
    Help: 7319
    Rate: 8299
    The m.2 discs will not fit to my colleague, unless through a grommet (which will be pointless, because it will either clog the x16 port, where the graphics card works, or it will sit on the x1 port, because there are no other boards).
  • #14 17055850
    grzechupluta
    One more question :) namely, what do you think about the crucial mx300, so I know that the bone is tlc but 3d nand so it's not too bad, I mainly expect the disk to see a performance jump compared to hdd, and mine sometimes has 100% consumption. I have the opportunity to buy a crucial mx300 275 gb and this is the second advantage because in my case the disk will be occupied around half of the space. For PLN 250 and I can still pick it up in person. A new disc with ttm that this someone sells with a guarantee but there is no proof of purchase (i.e. there is no guarantee) new discs in the store are for about PLN 350, so you will save PLN 100
  • #15 17056122
    dt1
    Help: 7319
    Rate: 8299
    Any SSD will be a performance leap in the transition from HDD. I tested the MX300, it works fine, I wouldn't buy it myself, but if someone were to force me to buy a TLC memory disk, it would probably be one of the candidates.
    At the price of PLN 250, this MX300 is even an interesting proposition, as long as it is not slaughtered (and this can be judged after watching the SMART disc - you can also confirm whether it is really new).
    Buying electronics without a warranty is quite risky, because even the best product may fall even after a few minutes of operation due to a possible factory defect. I would be tempted to do something like this, having at least a reliable seller's start-up warranty.
  • #16 17087081
    grzechupluta
    If anyone else could speak.
    if I have 70-80 gb files on goodram irdm, will this disk not slow down? because su800 apparently drops its performance drastically. How much space will be available for something around 110 gb? Thanks in advance for your answer.
The discussion revolves around selecting a 128GB SSD within a budget of 200 to 250 PLN, focusing on three models: ADATA SU800, ADATA Premier Pro SP920, and Goodram Iridium Gen2. Users express concerns about storage capacity, performance, and longevity. Recommendations lean towards the Goodram Iridium Gen2 for its MLC NAND, despite its weaker controller, and the ADATA SP920 for its solid performance and 5-year warranty. The importance of choosing a larger capacity SSD (240GB) to avoid future issues is emphasized. Alternatives like the Crucial BX300 and MX300 are also mentioned, with considerations regarding their TLC NAND and performance compared to HDDs. Users inquire about the impact of SSD fullness on performance and the risks of purchasing used drives without warranties.
TL;DR: If you’ll use 50%+ of the drive, "I would rather target 240–256GB models." Prefer MLC for consistency; all listed MLC options work well for normal use. [Elektroda, dt1, post #17052113]
Why it matters: This FAQ helps budget-focused upgraders pick a reliable SSD for Windows, apps, and everyday workloads without costly do-overs.
Which should I buy: ADATA SP920 or Goodram IRDM Gen2 at ~128GB?
Pick SP920 if you value consistency and warranty. It uses MLC, has a strong controller, and a 5‑year warranty, though writes are slightly slower. Goodram IRDM Gen2 also uses MLC and, despite a modest controller, handles standard desktop use well. Choose SP920 for the warranty and controller strength; choose IRDM Gen2 if price wins and your workload is typical. [Elektroda, dt1, post #17049886]
128GB vs 240GB—what’s the smarter choice for Windows and apps?
Go 240GB. It avoids reinstalling later when 128GB fills with updates and apps. As one expert said, “buy bigger once and don’t waste 2 times.” Several users upgraded soon after, adding cost and hassle. Start with 240GB to prevent space pressure. [Elektroda, atomic99, post #17048787]
Will a 120GB IRDM Gen2 slow down with 70–80GB used?
At that usage you’ll be over 50% full. Target 240–256GB to maintain headroom and stable performance. The MLC models discussed work well in normal use, but capacity margin helps keep speeds steady as files accumulate. [Elektroda, dt1, post #17052113]
Does copying one big file accurately show SSD speed?
No. One large file mostly shows sequential speed. Real workloads hit many small 4KB files and reveal different behavior. Check results that include 4K random reads/writes and mixed scenarios. As the expert noted, “uploading one file is a poor test.” [Elektroda, dt1, post #17050661]
Is Crucial BX300 120GB a good budget alternative?
Yes. It uses MLC and was available around PLN 199 for 120GB in the thread timeframe. It’s a solid pick if you want MLC on a tight budget. The expert purchased one specifically as a low-cost MLC option. [Elektroda, dt1, post #17049886]
Is a no‑receipt Crucial MX300 275GB for PLN 250 a safe buy?
It’s attractive, but protect yourself. “Any SSD will be a performance leap,” yet buying electronics without a warranty is risky. Even a good unit can fail minutes after power-on. Inspect SMART to confirm condition and insist on at least a start-up warranty from a reliable seller. [Elektroda, dt1, post #17056122]
How do I check an SSD before buying used or without a receipt?
  1. Ask the seller for a full SMART report screenshot.
  2. Verify low power-on hours and writes; confirm the model and serial.
  3. Get a start-up warranty and test boot or quick file copy before paying. [Elektroda, dt1, post #17056122]
Will an ADATA XPG SX6000 (PCIe 3.0 x2, M.2) work on an ASRock H110M?
No, that board lacks an M.2 slot. An adapter would either block the x16 GPU slot or sit in a slow x1 slot, making it impractical. Use a 2.5-inch SATA SSD instead on this platform. [Elektroda, dt1, post #17054412]
How much usable space do I get on a “120GB” SSD?
Windows shows about 111 GiB usable on a 120GB SSD. Manufacturers rate in decimal gigabytes, while operating systems display binary gibibytes, so the reported capacity appears lower. [“Why is the capacity of my drive different from what is advertised?”]
Does the controller matter more than NAND type here?
For typical desktop use, both options work well. SP920’s controller is stronger and backed by 5 years of warranty. IRDM Gen2’s controller is modest yet adequate for standard use. Choose based on warranty preference and price, not just controller specs. [Elektroda, dt1, post #17049886]
Is ADATA SU800 a bad pick compared to these MLC options?
This thread leans toward MLC for consistent performance and endurance. If you must buy TLC, the expert named MX300 as a viable candidate among TLC models. If price is close, pick MLC options like SP920 or IRDM Gen2. [Elektroda, dt1, post #17056122]
What price did the 240GB Goodram Iridium have in the thread?
It was reported at approximately PLN 320–330 via a price check link. If your local price is far higher, compare alternatives before buying. [Elektroda, atomic99, post #17050007]
Will Windows and apps feel faster even on the cheapest SSD vs HDD?
Yes. The expert stated, “Any SSD will be a performance leap.” Even entry-level SSDs remove HDD bottlenecks in boot, load, and update tasks. You will feel the difference immediately in daily use. [Elektroda, dt1, post #17056122]
Are there forum benchmarks for IRDM Gen2 120GB and 240GB?
Yes. The expert shared IRDM Gen2 benchmarks for 240GB and referenced another user’s 120GB results in the linked thread. Use those results to compare real performance. [Elektroda, dt1, post #17049886]
