Goodram IRDM PRO vs Crucial MX500 vs Samsung 860 EVO: 250GB SSD for Office/Gaming Use
Blade163 4920 10
Which 250GB SSD should I buy for office work, web browsing, and occasional light gaming: Goodram IRDM PRO, Crucial MX500, or Samsung 860 EVO?
IRDM PRO is the best pick here if you want the best compromise of price, quality, warranty, and endurance, because it uses a decent controller, MLC memory, and comes with a 5-year warranty [#17393354] Both the Crucial MX500 and Samsung 860 EVO are good drives too, but they are based on TLC memory, so the recommendation in the thread leans toward IRDM PRO [#17393354] For normal office/browser use and light gaming, the performance difference between these SSDs will usually be small and hard to notice by eye [#17394914] If you can find the older Iridium PRO, it is said to be the same drive as IRDM PRO, so the red stickers are not important as long as the warranty is the same [#17395159][#17395799] One reply also specifically recommends IRDM PRO GEN2, citing 60 months warranty and MLC memory [#17395752]
  • #1 17391908
    Blade163
    Rate: 14
    Hello. I'm thinking about choosing a 250GB SSD. I am considering Goodram IRDM PRO, Crucial mx500 and Samsung 860 EVO. I use the computer mainly for office tasks + browser, rarely games (rather undemanding). Which of these discs would you recommend or suggest another one? ADATA drops out
  • #2 17392088
    Felini
    Moderator
    Help: 124
    Rate: 433
    I have been using Samsung SSD 850 PRO disk for several years and for now there are no problems with it.
    I was prompted to buy good test results and a 10-year manufacturer's warranty.
  • #3 17393354
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
    IRDM PRO will be a good compromise of price, quality and warranty period. It is a disk on a relatively decent controller, good MLC memories and has a 5 year warranty. Both other designs are based on TLC memories, which is why I would choose IRDM PRO (despite the fact that MX500 or 860 EVO are quite good drives).
  • #4 17394755
    Blade163
    Rate: 14
    I'm just a little afraid that I've heard that they are quite often emergency, there are a lot of problems with the service and do not guarantee such performance as other SSDs.
  • #5 17394914
    dt1
    Help: 7319
    Rate: 8299
    As for the website, I don't know, I didn't have to use it, but I bought a three-digit number. Although not, one once fell (Iridium PRO, but it's the same disk before re-labeling). I realized the guarantee in Morelach without any problems.
    As for the performance it's probably - you can find disks faster and slower than those GoodRAM. However, my decision is influenced by the type of memory used. I prefer MLC memory than TLC, assuming that they can withstand more write cycles. But here everyone is choosing what they like.
    By the way - it's worth looking at benchmarks that are performed on large data samples. High-performance TLC disks often rely on a fairly large and fast buffer. The buffer has limited capacity, and when it ends, the disks are no longer that fast. TLC memories don't break speed records. Of course, under normal use, this buffer is rarely clogged. Just as it seldom happens, we notice the difference between a slightly worse and slightly better SSD "by eye". The difference must be large enough to see it, especially in standard use.
  • #6 17395123
    Blade163
    Rate: 14
    So I guess I'll decide for him. Compared to my HDD, I will notice a rather big difference, regardless of whether it breaks records or not.
    What I meant with the service was that I heard that it has no manufacturer's warranty, only the seller, which is a bit strange and hard to believe for me.
    If you can, just tell me if I'm thinking right. This disk before re-labeling is the usual black and newer is the one with red inserts? Because I'm a little mistaken that both versions can be in one store and once more the price is more expensive once.
  • #7 17395159
    dt1
    Help: 7319
    Rate: 8299
    There used to be GoodRAM Iridum PRO and GoodRAM Iridium products - without PRO (I skip completely lower models from the C / CX / CL series).
    Now there are models with red inserts, i.e. GoodRAM IRDM PRO and GoodRAM IRDM (without PRO).
    IRDM PRO is probably an exact copy of Iridium PRO (the same controller, the same declared all parameters on the manufacturer's website, probably the same memories, since it turned out so evenly).
    IRDM (without PRO) is ... it seems like a new disk, because it does not have much in common with the old IRDM - it is a completely different controller.
    If you are interested, it once fell into my hands IRDM (without PRO) and I measured it in several tests by contrasting the results of my much longer Iridium PRO (i.e. IRDM PRO now). https://www.elektroda.pl/rtvforum/topic3434173.html
  • #8 17395685
    Blade163
    Rate: 14
    So I understand that it's best and safest to be tempted by GoodRAM IRDM Pro, with red stickers?
  • #10 17395799
    dt1
    Help: 7319
    Rate: 8299
    If you find Iridium PRO (no red stickers), this is the same disk. If you also get a 5-year warranty on it, there is no reason to insist on the stickers.
  • #11 17395842
    Brozerihno
    Help: 28
    Rate: 44
    Even better my friend said that this Gen 2 got in a box from Iridium PRO :)
The discussion revolves around selecting a 250GB SSD for office tasks and occasional gaming, focusing on three models: Goodram IRDM PRO, Crucial MX500, and Samsung 860 EVO. Users highlight the Goodram IRDM PRO as a favorable choice due to its MLC memory, 5-year warranty, and good performance, especially compared to the TLC memory used in the other two models. Concerns about the reliability and service of Goodram products are mentioned, but users share positive experiences with warranty claims. The IRDM PRO is noted to be a rebranded version of the Iridium PRO, with similar specifications. Overall, the consensus leans towards the Goodram IRDM PRO for its balance of price, quality, and warranty.
