[Solved] Peugeot 407 2004 Petrol: Key Immobilizer Crossed Out Issue, 2 Remote-Control Keys, Diagbox Error
adamski123 25023 6
  • #1 17076505
    adamski123
    Help: 46
    Rate: 250
    Hello colleagues, such a Peugeot 407 2004 came to me in petrol The car has two keys with remote control for both starts, but one shows the message of the crossed out key, i.e. the car should not start, and the fire starts. Diagbox shows zero key errors I programmed again and it did nothing can anyone meet such a thing best regards
  • #2 17076553
    kamiloskop
    Help: 42
    Rate: 279
    Locks work normally? Ie they close and open
  • #3 17076558
    adamski123
    Help: 46
    Rate: 250
    Hello, locks work normally all zicher only when I insert this one key, the inscription CHECK OK pops up, and after a while the key is crossed out and the car starts normally, but with the second key there is no such problem
  • #4 17076578
    kamiloskop
    Help: 42
    Rate: 279
    So something is wrong with the key or coding
  • #5 17076600
    adamski123
    Help: 46
    Rate: 250
    Coding rather ok because such keys are often coded, and as for the key, the client says that before it was not strange to me because as the crossed out key it is either BSI spilled or the key damaged
  • #6 17081552
    tytan58
    Help: 42
    Rate: 153
    See in BSI how many keys and remotes read.
  • #7 17339726
    adamski123
    Help: 46
    Rate: 250
    Hello topic ended I added a new key
The discussion revolves around a 2004 Peugeot 407 petrol vehicle experiencing an issue with one of its remote control keys, which displays a crossed-out key symbol, indicating a potential immobilizer problem. Despite both keys being able to start the car, the problematic key triggers a "CHECK OK" message before the crossed-out symbol appears. Responses suggest that the issue may stem from either a damaged key or a malfunctioning BSI (Body Control Module). The user later resolved the issue by adding a new key, indicating that the original key was likely the source of the problem.
