[Solved] Ford Mondeo Mk4 1.8 TDCI: Hard Start on Hot Engine, Error P0087, and Fuel Pressure Sensor
PatCar51 10884 5
  • #1 17094344
    PatCar51
    Hello !
    As in the topic, I have a problem with the Ford Mondeo Mk4 1.8 TDCI.
    It fires hard on a hot engine.
    The computer diagnosis showed error P0087 (fuel pressure control valve), the pressure on the ramp during the warm start is from 1.5 to 2.5 bar, so in my opinion a little bit.
    Fuel filter replaced, old very dirty.
    Proven shaft position sensor resistance to hot and cold.
    I suspect that the culprit is this fuel pressure sensor in the pump, but is there any way to confirm this diagnosis?
    I would also like to add that after connecting the fuel system "briefly", i.e. bypassing the tank, wires, fuel filter, the car fires better.
  • #2 17094420
    migmig85
    Help: 85
    Rate: 337
    Check injections for transfers or disassembly and for a company that specializes in it.
  • #3 17094484
    PatCar51
    I will do an overflow test, and where do you suspect that it is the fault of the injectors?
  • #4 17094499
    migmig85
    Help: 85
    Rate: 337
    They may not be holding pressure on the CR bar.
  • #5 17094831
    kortyleski
    Help: 957
    Rate: 3860
    PatCar51 wrote:
    the pressure on the ramp during warm start is from 1.5 to 2.5 bar
    you need about 300bar to fire ...
  • #6 17107272
    PatCar51
    Fuel pump regeneration
