[Solved] ERR_PROXY_CONNECTION_FAILED in Chrome on Windows 7: Can't Change LAN Settings, Administrator Issue
Rafal_694 7209 4
  • Proxy settings locked by administrator policy
    #1 17099367
    Rafal_694
    Hello, I have a problem with internet access on the CHROME browser, windows 7.
    There is a message saying: ERR_PROXY_CONNECTION_FAILED '
    Following this lead I should simply uncheck the use of a proxy server and it should work. That's the problem here. After enabling "Change proxy settings ..." the "LAN settings" button is not illuminated and as a result I cannot uncheck it but what is important in this field is the annotation "Some settings are managed by the system administrator".
    The network diagnostic tool says:
    Troubleshooting completed successfully. Problems found: The remote device or resource does not accept the connection.
    Detailed information: The device or resource configuration (www.google.com) does not accept connections using the World Wide Web (HTTP) service port.
    After entering In CMD: ipconfig / all you can see:
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C: \ Windows \ system32> ipconfig / all
    Windows IP configuration
    Hostname. . . . . . . . . . . : Jola-Computer
    Primary DNS suffix. . :
    Node type. . . . . . . . . . . . : Hybrid
    IP routing enabled. . . . . . . : No
    WINS Proxy server enabled. . . . : No
    Wireless LAN card Wireless network connection:
    Connection specific DNS suffix:
    Description. . . . . . . . . . . . . . . : Broadcom 802.11n network adapter
    Physical address. . . . . . . . . . : 48-5A-B6-D3-81-C3
    DHCP enabled. . . . . . . . . . : Yes
    Auto configuration enabled. . . . : Yes
    Local Area Connection IPv6 Address. : fe80 :: 7513: 2bb4: f07a: 6cfb% 13 (Preferred)
    IPv4 address. . . . . . . . . . . . . : 192.168.0.103 (Preferred)
    Subnet mask. . . . . . . . . . : 255.255.255.0
    Rent obtained. . . . . . . . : March 12, 2018 10:39:30 PM
    The lease expires. . . . . . . . . : April 19, 2154 5:28:08
    Deafult Gateway. . . . . . . . . . : 192.168.0.1
    DHCP server. . . . . . . . . . . : 192.168.0.1
    IAID DHCPv6 ID. . . . : 340286134
    DHCPv6 client DUID: 00-01-00-01-21-A0-E6-F6-20-1A-06-A5-1E-3E
    DNS servers. . . . . . . . . . . : 192.168.0.1
    NetBIOS via Tcpip. . . . . . . : Activated
    Tunnel card isatap. {9A85EA0B-4CA5-43C4-B956-3B52BD00E3FC}:
    Media status. . . . . . . . . . .: Media disconnected
    Description. . . . . . . . . . . . . . . : Microsoft ISATAP card
    Physical address. . . . . . . . . . : 00-00-00-00-00-00-00-00 E0
    DHCP enabled. . . . . . . . . . : No
    Tunnel card Local connection * 3:
    Description. . . . . . . . . . . . . . . : Microsoft Teredo Tunneling Card
    I think there is no problem here. I entered DNS and other things manually without results. The firewall does not block this either.
    Fun fact from IE: The proxy server is not responding. Check the proxy server settings. 127.0.0.1:8080.
    What works? Firefox is working properly after disabling proxies, pinging properly in cmd. Internet via Wi-Fi has a connection. Dropbox updates files.
    Scans from the FRST program are attached.
    I also found a command in this forum that checks the entered proxy server in CMD, the answer was that there is no proxy server set.
    AdwCleaner 7 found two problems: PUP.Optional.Legacy and PUP.Optional.Prxy.SvrRST. There are no changes after deleting them.
    Please help. best regards
    • FRST.txt (22.99 KB) You must be logged in to download this attachment.
    • Addition.txt (35.38 KB) You must be logged in to download this attachment.
    Proxy settings forced to 127.0.0.1:8080
    #2 17099454
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Fixlist content for you:
    [code:1:4cb688a011]HKU\S-1-5-21-3742933652-956789917-4146397759-1000\...\MountPoints2: {cc195ede-cbb4-11e7-b78a-806e6f6e6963} - E:\Msetup4.exe
    HKU\S-1-5-21-3742933652-956789917-4146397759-1000\...\MountPoints2: {e027965b-cbc5-11e7-a8a1-201a06a51e3e} - G:\SETUP.EXE
    HKLM\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings: [ProxySettingsPerUser] 0 Proxy [funkcja włączona]
    ProxyEnable: [HKLM-x32] => Proxy [funkcja włączona]
    ProxyServer: [HKLM] => http=127.0.0.1:8080;https=127.0.0.1:8080
    ProxyServer: [HKLM-x32] => http=127.0.0.1:8080;https=127.0.0.1:8080
    AutoConfigURL: [HKLM] => http=127.0.0.1:8080;https=127.0.0.1:8080
    Tcpip\Parameters: [DhcpNameServer] 192.168.0.1
    Tcpip\..\Interfaces\{9A85EA0B-4CA5-43C4-B956-3B52BD00E3FC}: [DhcpNameServer] 192.168.0.1
    ManualProxies: 1http=127.0.0.1:8080;https=127.0.0.1:8080
    HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Ograniczenia type", 0
    FF Plugin: @Microsoft.com/GENUINE -> disabled [Brak pliku]
    FF Plugin-x32: @Microsoft.com/GENUINE -> disabled [Brak pliku]
    U3 a5g8lqoj; C:\Windows\System32\Drivers\a5g8lqoj.sys [0 ] (Microsoft Corporation) Brak pliku
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    It is worth adding to Fixlist:
    RemoveProxy:
  • #4 17100068
    dt1
    Help: 7315
    Rate: 8292
    Thanks for the good suggestion, I added an entry.
  • #5 17101399
    Rafal_694
    The fixlist.txt file has worked and the problem has disappeared.
    Thank you and best regards
