Changing the proxy address to 127.0.0.1:8080; Internet does not work
kowalek77 6480 3
  • #1 16399756
    kowalek77
    I have a problem with the internet. I am using chrome browser and I get the message: "no internet connection. Proxy is not working properly or the address is incorrect". The same for other browsers, some display the proxy server address given in the subject. Initially, it happened once in a while, now the internet does not work at all. Unplugging and connecting the cable or starting the computer does not help. Similarly on wi-fi. I have read similar topics and I think you need to write a log to FRST. I attach scans in the attachment. I read that the problem may be instalshield, which appears to me.
    I am asking for help and detailed instructions on what to do.
    Greetings.
    • FRST.txt (249.77 KB) You must be logged in to download this attachment.
    • Addition.txt (34.33 KB) You must be logged in to download this attachment.
  • #2 16399779
    sylweksylwina
    Help: 1881
    Rate: 2348
    If you set the proxy to localhost, it is not surprising that you do not have internet. Well, unless it's the malware that sets something different.
    Kolobos
    IT specialist
    Help: 17167
    Rate: 10448
    Next to frst.exe, create the Fixlist.txt file with the contents:
    Task: {4FCB21AD-D084-43CD-8B93-AF58372BACF1} - System32 \ Tasks \ Optimize Thumbnail Cache Files => Wscript.exe // nologo // E: jscript //BC:\ProgramData\InstallShield\Update\isuspm.ini < ==== NOTE
    HKU \ S-1-5-21-2128437163-3962589836-2916835154-1001 \ ... \ Policies \ Explorer: []
    HKU \ S-1-5-21-2128437163-3962589836-2916835154-1001 \ ... \ MountPoints2: {e74c5b4e-0d96-11e7-a5a9-34e6adf42e36} - "G: \ SETUP.EXE"
    HKLM \ SOFTWARE \ Policies \ Microsoft \ Windows \ CurrentVersion \ Internet Settings: [ProxySettingsPerUser] 0 Proxy [function enabled]
    ProxyEnable: [HKLM-x32] => Proxy [function enabled]
    ProxyServer: [HKLM] => http = 127.0.0.1: 8080; https = 127.0.0.1: 8080
    ProxyServer: [HKLM-x32] => http = 127.0.0.1: 8080; https = 127.0.0.1: 8080
    AutoConfigURL: [HKLM] => http = 127.0.0.1: 8080; https = 127.0.0.1: 8080
    ManualProxies: 1http = 127.0.0.1: 8080; https = 127.0.0.1: 8080
    RemoveProxy:
    HKLM \ SOFTWARE \ Policies \ Microsoft \ Internet Explorer: Limitations
  • #4 16399835
    kowalek77
    I did as you said, everything works fine. Thank you :)
