Choosing a Superzoom Compact: Nikon P610, B700, Panasonic FZ82, Sony HX350 or Other Options?
sztani1 6513 16
Which used superzoom compact should I buy for forest, wildlife, family photos indoors, and short videos?
If you stay with this budget class, the Panasonic route is the best compromise, and several replies point to the FZ300/FZ200 as the stronger buy because they give much better image quality than the huge-zoom models, with constant f/2.8 and decent AF; the FZ300 also adds 4K video [#17115829][#17109375] The thread also warns that all these cameras use tiny 1/2.3" sensors, so low-light forest shots, indoor family photos, and long-zoom images will be noisy and softer than you might expect [#17100220][#17109375] If you must choose only from the original four, the Panasonic FZ82 looks best on paper because it is brighter than the Nikon B700 (f/2.8-5.9 vs f/3.3-6.5) and the Sony HX350 (f/2.8-6.3), and it supports RAW [#17101248] One reply simply recommended the Nikon B700, but the more detailed advice in the thread is to prioritize lens brightness and overall image quality over zoom reach [#17100005][#17100220]
  • #1 17099798
    sztani1
    Rate: 11
    I warmly welcome :grin:
    I would like advice on choosing the superzoom compact. I am a novice who has been very attracted to photography recently. The camera should be second hand!
    Why superzoom? Because the main purpose of the camera is photos in the forest and in the fields, animals and birds, sometimes open air, family photos indoors, of course, some short videos commemorating family episodes also come into play.
    I know that the best option would be a camera with a 1.0 matrix, unfortunately I can't afford it right now.
    Such a best option for me would be Canon PowerShot G3 X or Lumix DMC-FZ1000, unfortunately finances ...
    But to the point, I found four models, unfortunately I can't decide which one to choose, please help!
    - Nikon COOLPIX P610
    - NIKON COOLPIX B700
    - PANASONIC LUMIX DC-FZ82
    - Sony DSC-HX350
    Link to compare: https://www.optyczne.pl/p...=2128&add3=2123
    Maybe something else you recommend?
  • #3 17100150
    marcode
    Help: 88
    Rate: 76
    There is a lot of it, but make sure before buying whether this quality of photos satisfies you, the amount of noise in poor lighting conditions can disappoint, photos in rooms with a built-in lamp will give miserable quality in the same way, in the forest the amount of light is not crazy, extreme zooms also degrade picture.
  • #4 17100197
    sztani1
    Rate: 11
    I am aware of the fact that with 40-50-60 zoom the image quality is dramatically lost! (40x-60x zoom treats more like a bajer!) From what I knew, the greater the ISO range, the greater the noise and amount of light? (correct me if I'm wrong)
    In the forest I will use max 15x - 20x! So I suspect that with such a zoom I will not lose much on the quality of photos? (if I'm wrong, bring me down)
    I chose the above models (superzoom) because, in my opinion, the layman, they are at a similar technical level as similar cameras with a zoom range of 15x - 20x, and above all they are affordable!
    If you would recommend something from the models I mentioned, which one would it be? if any other, which one?
    Best regards and thanks for your interest
    marcode
    Help: 88
    Rate: 76
    The problem is the surface of the matrix, the smaller you need to raise the ISO, which introduces noise and degrades the image, plus any larger focal length or zoom causes that the aperture decreases, i.e. it is darker and you need to raise the ISO again.
    ISO does not increase / decrease the light but in short increases the sensitivity of the matrix, we gain brightness and lose quality.
  • #6 17100298
    sztani1
    Rate: 11
    In the model I mentioned, the matrices are the same size, 1 / 2.3 inches!
    In what focal range the light sensitivity remains at f.2.8?
    PS: I hope you understand what I mean, best regards
  • #8 17100313
    marcode
    Help: 88
    Rate: 76
    The problem is those 1 / 2.3 "microscopic matrices and nothing can be done about it, sometimes it can be even worse than on a good sound.
    Optics has f / 2.8 but in what focal range or at what zoom it is already necessary to check in the description / tests.
  • #9 17100340
    sztani1
    Rate: 11
    Piterrr, thanks for the link !!
    marcode, I know that 1 / 2.3 inch matrices are weak, unfortunately cameras with 1 inch matrices. they are not available to me at the moment! (I wrote about it in the first post) The sound matrices may be the same, but there is no zoom and stabilization !!
    Maybe you can advise what to choose from the above models? I can add that Panasonic and Sony models are available as new and not second-hand (I found Sony discounted)
  • #11 17101248
    sztani1
    Rate: 11
    Only three models left on the battlefield :cunning:
    - Sony DSC-HX350
    I compare the specifications of Nikon and Panasonic -https: //www.optyczne.pl/porownaj.php? co = camera & how much = 3 & add0 = 2128 & add1 = 2122 & add2 = 2123
    I noticed it, it illuminated: Nikon-f / 3.3-6.5 - Panasonic-f / 2.8 - 5.9 (sony f / 2.8 - 6.3)
    Panasonic is the brightest at its focal length?
    in addition, both save the image in RAW format! which, unfortunately, is lacking in sonia :cry:
  • #12 17101271
    Pedros050
    Help: 2471
    Rate: 3927
    So probably only NIKON COOLPIX B700 remains.
  • #13 17109275
    sztani1
    Rate: 11
    I think I decided on Panasonic Lumix, only on the FZ300 or FZ 200 !!!
    Comparing the FZ300-200 model with the Coolpix B700, the specification speaks for Lumix :wink: In favor of Lumix, speaks constant light sensitivity f 2.8!
  • #14 17109375
    marcode
    Help: 88
    Rate: 76
    I do not understand the purchase of such cameras, a microscopic matrix with hopeless effective resolution, poor dynamics, high noise at ISO 400, great zoom but giving insufficient quality, optical brightness is a joke in these parameters.
    A better effect can be obtained with any mirrorless kit lens, so what if you use a large zoom as the recorded image will be worse than without such a large zoom on a large aps-c sensor?
    I know that the price is important, but there is a lot of used equipment, and I don't recommend throwing money out for such a superzom.
  • #15 17115829
    arq-maile
    a very good choice - you don't have a 100x zoom, but you get a very good image, for a compact quite good AF (you will appreciate the F / 2.8 at the long end) - the cousin has the FZ200 and is very happy - the lenses in both models are identical if the budget lasts - the successor has filming in 4K, probably even some sealing and slightly better ergonomics
  • #16 17120306
    sztani1
    Rate: 11
    I bought it however Lumixa FZ200 :D
    The camera is very good for me, an amateur, apart from the automatic mode (iA) there are many possibilities for manual settings !!!
    Thanks to everyone for your time !!!
    greetings :sm9:
  • #17 17120507
    arq-maile
    @ sztani1 you will be pleased ;-)
The discussion revolves around selecting a superzoom compact camera suitable for a novice photographer interested in wildlife and family photography. The user is considering second-hand options and has narrowed it down to four models: Nikon COOLPIX P610, Nikon COOLPIX B700, Panasonic Lumix DC-FZ82, and Sony DSC-HX350. Key considerations include image quality, low-light performance, and zoom capabilities. Participants emphasize the importance of sensor size and aperture, noting that smaller sensors (1/2.3 inch) can lead to increased noise at higher ISOs. The Panasonic Lumix models are highlighted for their constant f/2.8 aperture, which is advantageous for low-light conditions. Ultimately, the user decides on the Panasonic Lumix FZ200, citing its manual settings and overall performance for amateur photography.
TL;DR: For used superzooms, FZ200/FZ300 shine with constant f/2.8 and 4K on FZ300; “you don’t have a 100x zoom, but you get a very good image.” Choose brighter lenses and RAW over extreme zoom. [Elektroda, arq-maile, post #17115829]
Why it matters: This FAQ helps beginners choose a capable used superzoom for wildlife, indoor family photos, and occasional video.
Which used superzoom did forum advice favor for wildlife and family?
Advice favored Panasonic Lumix FZ200 or FZ300. The lens is identical, and “you will appreciate F/2.8 at the long end.” The FZ300 adds 4K and slightly better ergonomics. Both prioritize image quality over extreme 100x‑style zoom claims. [Elektroda, arq-maile, post #17115829]
Nikon B700 vs Panasonic FZ82 vs Sony HX350 — which is brighter and supports RAW?
From the comparison: B700 f/3.3–6.5, FZ82 f/2.8–5.9, HX350 f/2.8–6.3. On paper, the FZ82 is brightest. Nikon and Panasonic record RAW; Sony HX350 lacks RAW. If you edit, that brightness plus RAW can outweigh sheer zoom. [Elektroda, sztani1, post #17101248]
Does extreme zoom hurt image quality?
Yes. Expect increased noise in poor light, and extreme zooms degrade image quality. Indoors, built‑in flash often delivers poor results. Forest scenes also offer limited light, compounding blur and noise at long focal lengths. [Elektroda, marcode, post #17100150]
What does ISO really do on these cameras?
ISO does not add light; it amplifies the sensor signal. Raising ISO brightens exposure but increases noise and reduces detail. Smaller sensors push ISO higher as the lens darkens while zooming. “We gain brightness and lose quality.” [Elektroda, marcode, post #17100220]
What ISO limits should I expect on 1/2.3-inch superzooms?
Expect visible noise at modest ISO. An experienced user noted high noise from ISO 400. Dynamic range is limited compared with APS‑C, affecting shadows and highlights in challenging scenes. Plan your settings and expectations accordingly. [Elektroda, marcode, post #17109375]
On which models is f/2.8 constant across the zoom?
Panasonic FZ200 and FZ300 use a constant f/2.8 lens across the full zoom range. This helps preserve shutter speed at telephoto and restrain ISO increases in dim light. [Elektroda, sztani1, post #17109275]
Do these cameras shoot RAW for better editing?
Nikon COOLPIX B700 and Panasonic FZ82 save images in RAW. Sony HX350 lacks RAW, reducing post‑processing headroom. If you plan to edit, prioritize models with RAW support. [Elektroda, sztani1, post #17101248]
Mirrorless APS‑C vs superzoom — which gives better image quality?
A forum expert argued for mirrorless APS‑C kits when quality matters. “A better effect can be obtained with any mirrorless kit lens.” Superzooms trade image quality for reach and convenience, especially as ISO rises. [Elektroda, marcode, post #17109375]
Can I get decent indoor photos with these superzooms?
Indoors is challenging for 1/2.3‑inch sensors. With room lighting and a built‑in flash, results can be poor. In dim spaces or forests, expect noise and blur at longer focal lengths unless subjects stay still. [Elektroda, marcode, post #17100150]
FZ200 vs FZ300 — what changed and why upgrade?
Both share the same fast lens. The FZ300 adds 4K video and improved ergonomics. You will appreciate f/2.8 at the telephoto end for wildlife. Choose FZ300 if you need the video bump and handling tweaks. [Elektroda, arq-maile, post #17115829]
Quick 3‑step check before buying a used superzoom
  1. Run the full zoom; test autofocus, stabilization, and every control.
  2. Shoot sample photos and video at base ISO and a higher ISO.
  3. Inspect files at 100% on a computer for dust, hot pixels, and uneven sharpness. [How to Buy a Used Camera]
Where can I learn exposure basics to improve results?
Use the exposure triangle guide linked in the thread. It explains aperture, shutter speed, and ISO interactions clearly. Practice those relationships and review your images to build skill. [Elektroda, Pedros050, post #17100309]
What did the original poster finally buy, and were they happy?
They bought a Panasonic Lumix FZ200. They called it very good for an amateur and praised its many manual options alongside auto mode. Satisfaction was high. [Elektroda, sztani1, post #17120306]
Do all candidates share the same sensor size?
Yes, the models discussed used 1/2.3‑inch sensors. That common platform keeps costs down in this class. [Elektroda, sztani1, post #17100298]
