[Solved] Scania 4 2002 - Position Lamps Not Working on Tractor & Semi-trailer: Dipped, Road, Turn Signals
maro pl 10830 5
  • #1 17100779
    maro pl
    Rate: 77
    Hello everyone, the problem is the following Scania4 2002, no position lights on the whole set of tractor + semi-trailer, only dipped + road lights are in the tractor, i.e. front + turn signals, stop, reversing in the tractor and trailer, please help
  • #2 17102463
    marcin.koz2910
    Help: 91
    Rate: 387
    did you check the basics ?? i.e. fuses, relays and position light switch?
    if so, it remains to look for a circuit break
  • #3 17102612
    maro pl
    Rate: 77
    I replaced the position light relay and so far it is fine
  • #4 17102634
    marcin.koz2910
    Help: 91
    Rate: 387
    Exactly in these models, relays often fall, you should pay attention to them in the first place
  • #5 17102642
    maro pl
    Rate: 77
    I had the relays and replaced but used and it took a while and that's the end, so I bought one new one on Friday, I will know if anything helped
  • #6 17116558
    maro pl
    Rate: 77
    replacing good brand relays helped
