Junkers WRDP 11-2B Stove - Error E9, Burner Won't Start, Broken Elbow with Sensor Issue
misiek962 19203 2
  • #1 17101442
    misiek962
    Gentlemen, I have a problem with the stove - error E9 jumped out and the burner does not start at all. I will only add that my elbow has broken, which has a sensor. The elbow has been soldered and unfortunately the stove does not start. In the manual I read that the E9 error is the activation of the heating sensor from the temperature, but would it be?
    Junkers WRDP 11-2B Stove - Error E9, Burner Won't Start, Broken Elbow with Sensor IssueIMAG02..jpg (2.12 MB)You must be logged in to download this attachment.
  • #2 17101587
    electroshock
    Rate: 21
    So quickly to fire up, disconnect the cables from the sensor and leave it loose or connect them together, I don't remember anymore. Of course, the overheating protection does not work then, eventually replace the sensor.
  • #3 17101724
    serwisszulborski.pl
    Heating systems specialist
    Help: 360
    Rate: 1448
    The temperature limiter (frost has damaged the sensor) on the elbow urgently to be replaced, bypassing protections is prohibited.
