Junkers WRDP 11-2b EA Error Code: Ionization Electrode Issue, Ignition & Gas Pressure - DIY Fix?
fraksipon 26766 6
  • #1 17270764
    fraksipon
    Rate: 31
    I get the EA error code. I replaced the battery with new ones.
    I checked what it means and is written
    No signal from the ionization electrode (digital display shows EA).
    I will check back tomorrow, because maybe it was the gas pressure that caused the heater not to start.
    When turning on the heat of water, the ignition works smoothly and I see as if it made a small flame and supported it.
    Is this the reason for this behavior that you know that I can safely remove myself or call the service right away? If the website is in what order, what are the amounts?
    The device is 2.5 years old
    [Film: 7c5d77a6bc] https://filmy.elektroda.pl/30_1528745850.mp4 [/ film: 7c5d77a6bc]
  • #2 17270955
    piracik
    Help: 557
    Rate: 1978
    Probably defective automation or puncture on the ionization electrode.
    A service technician will look worse after these 2.5 years of operation. By the way, check the draft and gas tightness.
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Quickly to get hot water you need to clean the electrode marked in the picture. Use fine sandpaper for cleaning.
    There is a hole in the heater. There are no screws holding the pilot burner.
    The visit of an authorized service technician is obligatory.
  • #4 17271467
    fraksipon
    Rate: 31
    I only have screws, I removed them for cleaning.
    You have to weld it, I think. What order does such welding cost and how long can it be durable?
    On the other hand, it is Junkers who is 3 years old and does not look like a factory defect?
  • #5 17611267
    jacekczewa
    Help: 14
    Rate: 139
    Hello. I have a question about the design of the heater itself ... does the heater have a sheet metal cover from below so that no "gutters" can be seen and whether when mounting in place of the old Termet pg17, these connection hoses are sufficient because as we know in the thermet it is cold on the left and warm on the right.
  • #6 17611364
    valdimazur
    Help: 30
    Rate: 111
    The set does not include a cover to cover "gutters". They were produced by the company http://instal-gaz.www4b.pl/. Hoses are enough for connection (you have to cross them)
  • #7 17611368
    jacekczewa
    Help: 14
    Rate: 139
    Thank you for the quick reply
The discussion revolves around the EA error code on the Junkers WRDP 11-2b heater, indicating a potential issue with the ionization electrode. The user has replaced the battery and suspects that gas pressure might be affecting the heater's operation. Responses suggest that the ionization electrode may be defective or dirty, and cleaning it with fine sandpaper is recommended. A service technician's visit is advised for further inspection, especially given the device's age of 2.5 years. The user also inquires about the cost and durability of welding repairs, indicating concerns about the heater's reliability after a relatively short period of use.
