[Solved] Mondeo MK4 2.0 145 HP: Disassemble Fuse Box, Access R1 Relay Wires & Check Fuses/Relays
leoleoleoleo 21042 3
  • #1 17102596
    leoleoleoleo
    Rate: 41
    How to disassemble the fuse box and more specifically get under the fuses / relays to check the wires? Has anyone disassembled this box? I mainly care about the part marked by the outline because I want to get to the R1 relay wires
    • Mondeo MK4 2.0 145 HP: Disassemble Fuse Box, Access R1 Relay Wires & Check Fuses/Relays skrzynka bezpiecznikow MK4.jpg (107.04 KB) You must be logged in to download this attachment.
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Unplug the clamp from the battery, unscrew the screw on the power supply of the box these red wires and remove them. Then unplug the two plugs that are plugged into the box, then on the sides you have the box's protections that you need to simultaneously unblock and the whole box comes out upwards and you have access to the fuse and relay cables from below.
  • #3 17102729
    leoleoleoleo
    Rate: 41
    Thanks a lot. IM going to work. I thought that it would be possible to dismantle / lift only the marked part and not move the rest, but if so, I would lift everything to get to the wires.
    Added after 7 [hours] 13 [minutes]:
    Managed to. Wires on top. I wonder who gave such thin wires to the control circuit to the starter relay. Now, without the diagram, I have to look at the bundle to see where they are running and check in turn where the voltage drops. If someone has a Mondeo MK4 ignition scheme, please, and disassembly of the fuse box is exactly as a colleague wrote above.
  • #4 17106171
    leoleoleoleo
    Rate: 41
    The box is disassembled as described above. You do not have to watch the wires because they will not come out when lifting. After lifting, you can see which wires are in which place and in what colors they run, which makes it much easier when looking for a problem with the installation.
