The fan (blower) is still running in the Defro oven with the feeder
aneta07 39132 11
Why does the blower in my Defro Comfort 30 kW boiler keep running even when the set temperature is reached, and what should I do?
The most likely cause is a fault in the controller’s fan control circuit, not the temperature sensor, so the controller should be serviced or repaired [#17106403] First check whether the blower can be tested from the instructions and then save your settings and restore the controller to factory defaults [#17104723] If the fan still runs continuously after a factory reset, a damaged triac or other output stage in the Tech Defro K1Pv4 controller is a likely culprit [#17103793][#17104683] One user with the same Comfort controller reported that it can hang around 60°C and keep the fan running even when the actual temperature is already above the setpoint [#17104079] Another case confirmed that after a blower test passed and the controller was reset, the blower still kept blowing at set and current temperature 60°C, pointing again to the controller rather than the fan itself [#17105936]
  • #1 17103722
    aneta07
    Rate: 25
    Hello, I have a Defro Comfort 30 kW oven with a feeder set for the machine, but it has eaten too much (from November to now 8 tons of eco-pea coal) and changed it to manual. It did nothing and I returned to the machine and since then I have been thinking about the fan that is under the feeder. What should I do, all the time it goes even when it reaches the selected temperature, please help, maybe someone had it too? The oven's current temperature of 58 degrees, set 58 degrees and the blower keeps turning, it will not even stop for a few minutes. Help
  • #2 17103793
    tkaczu1
    Help: 22
    Rate: 92
    The reason probably lies in the controller, reset it to factory settings if there is such an option. The fan control path may also be damaged.
  • #3 17104039
    aneta07
    Rate: 25
    tkaczu1 wrote:
    Write what model of driver, there are triac short circuits in the driver and then it works constantly
    Tech Driver
  • #4 17104075
    Adam-T
    Help: 834
    Rate: 1096
    aneta07 wrote:
    Tech Driver
    And you signed up.
    I have, for example, an Opel car and be smart and guess which model of this Opel. ;)
  • #5 17104079
  • #6 17104683
    aneta07
    Rate: 25
    Adam-T wrote:
    aneta07 wrote:
    Tech Driver
    And you signed up.
    This is the Tech Defro K1Pv4 driver
  • #7 17104723
    Adam-T
    Help: 834
    Rate: 1096
    In the instructions they wrote that it is possible to test the blow-in fan - do it. If nothing helps, save your settings and restore the controller to factory settings as a colleague above.
  • #8 17105936
    aneta07
    Rate: 25
    My husband did a blower test and came out ok. Then he set the oven to factory settings and the blower keeps on talking does not turn off even for a moment. The temperature is set at 60 degrees, the current temperature also 60 degrees and further blows. Help
  • #9 17106403
    tkaczu1
    Help: 22
    Rate: 92
    If the pump reacts correctly to temperatures, it excludes damage to the temperature sensor. Most likely, the fan control path in the controller is damaged. Service controller.
  • #10 17106450
    hajtaler
    Help: 52
    Rate: 78
    The fan works when reaching the set value with high power or maybe minimal? Pierces the set or oscillates all the time around the set? Because if so, everything is okay - the driver working on the machine (PID) strives for continuous operation. Burning 8ton says nothing when you do not specify the heating surface and degree of insulation. The power of the boiler suggests that you heat a cottage which is 500 m or half smaller without insulation and these 8ton are quite normal
  • #11 17106509
    aneta07
    Rate: 25
    Boiler power as I wrote Defro 30 kw heats the surface of 250m2 + boiler 140. At the back of the furnace I have a 55-way mixed valve, 55 degrees, I have no valves on the radiators. The house is insulated. Maybe some other settings are to be done I do not know. During feeding, the blower works faster but then, despite the temperature reached, blows all the time but works slower. Please tell me if the blower is meant for this flap to be open all or some percentage and blocked.
  • #12 21690948
    kubiesmonika
    Hello .
    Please help me with my cooker.
Discussion about a Defro Comfort 30 kW boiler with feeder where the blower/fan keeps running continuously even after reaching the set temperature. Suggested causes included controller malfunction, damaged fan control circuit, or incorrect settings. Troubleshooting steps mentioned were testing the blower, restoring factory settings, and checking whether PID control behavior is normal. The author reported that the blower test passed and factory reset did not solve the issue; the boiler still blows at full or reduced speed at the target temperature, with concern about whether the flap should remain open only partially.
TL;DR: OP burned 8 tons of eco‑pea coal; “the driver working on the machine (PID) strives for continuous operation.” Fix by testing the fan, trying factory reset, then servicing a failed fan control path/triac if needed. [Elektroda, hajtaler, post #17106450]
Why it matters: This FAQ helps Tech/Defro owners diagnose a blower that won’t stop after reaching set temperature.
Why does my blower keep running after the boiler reaches temperature?
In machine/PID mode, the controller aims for stable heat and may keep the fan spinning slowly near the setpoint. As one expert notes, “the driver working on the machine (PID) strives for continuous operation.” This is expected behavior when the temperature oscillates around the set value. [Elektroda, hajtaler, post #17106450]
How do I test the blow‑in fan and try a safe reset on Tech/Defro?
Use the controller’s built‑in fan test, as described in the manual. If the test passes, save your settings and restore factory defaults to rule out bad parameters. Re‑enter your settings afterwards and observe if behavior changes. [Elektroda, Adam-T, post #17104723]
The fan test passed and a factory reset didn’t help—what next?
Service the controller. “Most likely, the fan control path in the controller is damaged.” A shorted triac or failed output stage can keep the blower energized even at the setpoint. Only repair or replacement resolves a hardware fault. [Elektroda, tkaczu1, post #17106403]
Could a bad temperature sensor cause a constantly running fan?
Unlikely if other circuits (like the pump) react correctly to temperature. That behavior indicates the sensor reads fine. A stuck fan with good readings points back to the controller’s fan control path. [Elektroda, tkaczu1, post #17106403]
What does “triac short” mean for this boiler controller?
It refers to a failed switching component in the driver that can hold the fan output on continuously. Users reported that when the triac shorts in the driver, the fan “works constantly,” requiring service. [Elektroda, aneta07, post #17104039]
My controller hangs near 60 °C and the fan never stops. Is this known?
Yes. A user with a Comfort controller (blue desktop) saw hangs around 60 °C. During those hangs, the fan ran continuously despite exceeding the setpoint. That points to controller behavior rather than the sensor. [Elektroda, 65469, post #17104079]
Is 8 tons of eco‑pea coal in one heating season abnormal?
Context matters. For a 30 kW unit and weaker insulation, a member noted that 8 tons over winter can be quite normal. Boiler oversizing also raises consumption when modulation is limited. [Elektroda, hajtaler, post #17106450]
How much fuel did the original poster actually report using?
They reported about 8 tons of eco‑pea coal from November to mid‑March while troubleshooting the blower behavior. That concrete figure provides a baseline for comparison. [Elektroda, aneta07, post #17103722]
Which controller model is in this thread’s case study?
The system uses a Tech Defro K1Pv4 driver on a Defro Comfort 30 kW boiler. Matching your model is vital before applying settings or diagnostics. [Elektroda, aneta07, post #17104683]
Will a factory reset always stop a stuck fan?
No. In this case, the fan kept running even after restoring defaults. If PID behavior is ruled out, hardware service is the next step. [Elektroda, aneta07, post #17105936]
What heating area was mentioned for the 30 kW boiler in this thread?
About 250 m² was reported. Oversized boilers serving moderate areas tend to cycle or modulate continuously, which can keep fans active in PID mode. [Elektroda, aneta07, post #17106509]
What’s the best way to ask for help so others can diagnose fast?
Always provide the exact controller/boiler model, not just the brand. As one member quipped, saying only “I have an Opel” isn’t enough to diagnose. List setpoints, modes, and what you already tried. [Elektroda, Adam-T, post #17104075]
