[Solved] Proxy Server Issue: Can't Disable, Internet Down, FRST Scan Results Attached - Troubleshooting
gmeros 3726 7
  • #1 17110062
    gmeros
    As in the topic, I have a problem with the proxy server, it keeps turning on and it cannot be "unchecked" (picture attached), so the Internet is completely down for me. Following the advice from other topics, I did a scan with FRST but I don't know what to do next. I attach the scans in the attachment.
    • Addition_17-03-2018 19.48.18.txt (38.08 KB) You must be logged in to download this attachment.
    • FRST_17-03-2018 19.48.18.txt (47.9 KB) You must be logged in to download this attachment.
    • Proxy Server Issue: Can't Disable, Internet Down, FRST Scan Results Attached - Troubleshooting 20180317_200336.jpg (8.43 MB) You must be logged in to download this attachment.
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    gmeros wrote:
    As in the topic, I have a problem with the proxy server, it keeps turning on and cannot be "unchecked" (picture attached),
    What antivirus program do you have? Avast maybe?
  • #3 17110142
    gmeros
    There was Avast but I uninstalled it because I thought it was blocking.
    FRST fixlist removes proxy and McAfee leftovers
    #4 17110147
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    Odinstaluj: McAfee Security Scan Plus
    Wykonaj Fixlist.txt dla FRST:
    (McAfee, Inc.) C:\Program Files\McAfee Security Scan\3.11.690\SSScheduler.exe
    ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => -> Brak pliku
    Task: {48CECAFD-45E7-4716-835E-365D0B5C67F4} - \Optimize Thumbnail Cache Files -> Brak pliku Brak pliku Proxy [funkcja włączona]
    ProxyServer: [HKLM] => http=127.0.0.1:8080;https=127.0.0.1:8080
    ProxyServer: [HKLM-x32] => http=127.0.0.1:8080;https=127.0.0.1:8080
    AutoConfigURL: [HKLM] => http=127.0.0.1:8080;https=127.0.0.1:8080
    ProxyEnable: [S-1-5-21-1863097155-17407895-823737308-1001] => Proxy [funkcja włączona]
    ProxyServer: [S-1-5-21-1863097155-17407895-823737308-1001] => http=127.0.0.1:8080;https=127.0.0.1:8080
    Hosts: 0.0.0.1 mssplus.mcafee.com
    ManualProxies: 1http=127.0.0.1:8080;https=127.0.0.1:8080
    RemoveProxy:
    HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer: Ograniczenia "hxxp://www.google.pl/ig","hxxp://www.key-find.com/"
    U3 aswbdisk; Brak ImagePath
    S3 intaud_WaveExtensible; \SystemRoot\system32\drivers\intelaud.sys [X]
    2018-03-10 20:46 - 2018-03-10 20:47 - 000000000 ____D C:\ProgramData\McAfee Security Scan
    2018-03-10 20:46 - 2018-03-10 20:46 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McAfee Security Scan Plus
    2018-03-10 20:46 - 2018-03-10 20:46 - 000000000 ____D C:\Program Files\McAfee Security Scan
    2018-03-08 23:37 - 2018-03-08 23:37 - 000000000 ____D C:\Program Files\AVAST Software
    2018-02-28 20:46 - 2018-02-28 20:46 - 000000000 ____D C:\ProgramData\McAfee
    2018-02-22 22:19 - 2018-02-22 22:19 - 000000000 ____D C:\ProgramData\Bitdefender
    2018-02-22 22:14 - 2018-02-22 22:14 - 000000000 ____D C:\Users\micha\AppData\Roaming\QuickScan
    2018-02-22 22:07 - 2018-02-22 22:07 - 000048773 _____ C:\ProgramData\agent.1519333629.bdinstall.bin
    2018-02-22 22:07 - 2018-02-22 22:07 - 000000000 ____D C:\ProgramData\Bitdefender Agent
    Po wykonaniu usun katalog C:\FRST i to wszystko.
    W ustawieniach Chrome wylacz przywracanie stron po starcie, ustaw na pusta strone.
    jdubowski
    Help: 2511
    Rate: 2804
    Something went wrong when uninstalling - reinstall it, because now if there is no proxy built in Avast, you can see what effect ...
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10454
    @jdubowski just do what I gave.
    Avast does not set up a proxy, usually crap activators (windows / office etc) or other infected program cracks do.
  • #7 17110221
    gmeros
    It works. Thank you very much ;)
  • #8 17110225
    gmeros
    As in the description ;)
The user is experiencing issues with a persistent proxy server that cannot be disabled, resulting in a complete loss of internet connectivity. After conducting a scan with FRST, they seek guidance on the next steps. Responses suggest uninstalling McAfee Security Scan Plus and using a provided Fixlist.txt for FRST to remove proxy settings. The user previously uninstalled Avast, believing it was causing the issue, but was advised to reinstall it to check for proxy configurations. Ultimately, following the provided instructions resolved the issue.
