LENOVO YOGA 300 - Does not start, only the LENOVO logo is visible.
XeeSTV 5844 3
  • #1 16602321
    XeeSTV
    Hi, just like the subject.
    The problem appeared right after I decided to restart the laptop during factory reset, I do not know how to turn on safe mode again - Windows 10, I click F8, F8 + SHIFT .. nothing happens.
    Thanks in advance for your help! :)
  • #2 16602416
    Przemko21
    Help: 110
    Rate: 307
    Try to press F8 first and then the POWER button - maybe it will help.
    It is also likely that your system boot has failed. If nothing helps create a recovery media for Windows 10 and then you can restore the bootloader.
  • #4 16602537
    safbot1st
    Help: 2719
    Rate: 1585
    Embed the SMART disk from a bootable MHDD. I assume you can enter the BIOS to change the boot to USB.
