HUAWEI P9 LITE - Fast Discharging Battery, 50% Drain in a Day, Wi-Fi & Data Off, Saving Mode
Morfeusz1970 11880 3
  • #1 17121045
    Morfeusz1970
    For some month I have a problem with a battery that discharges up to 50% during the day. I have been on the phone for 16 months. I do not talk too much, data transmission switched off, wi-fi turned off, set battery saving mode. The question is, what consumes me so much battery?
  • #2 17121139
    procsa
    Help: 173
    Rate: 364
    At 99% some application does not allow the system to go to sleep, install some program to check the drain of the battery and you will know if the battery is not dead ... Or a factory reset will also help, but it will erase everything :)
  • #3 17122828
    seba694637
    Help: 11
    Rate: 115
    1. CPU spy program - check if the phone actually goes into sleep mode.
    2. Is the battery more quickly discharged in the cold?
  • #4 17124976
    Morfeusz1970
    Thank you for the information, it did not matter if at home or in the cold, it would be unloaded quickly. Recently there was a new update for the phone and the battery has stopped discharging so quickly.
