ZTE MF 286 Router from Orange: Missing Band Selection Options - Firmware Update & Aggregation
adrian92198 17487 12
Why are the LTE band selection options missing on my Orange ZTE MF286 router, and how can I enable manual band selection and aggregation?
On the Orange ZTE MF286, the stock firmware does not seem to expose manual LTE band selection, so restarting and updating alone will not bring those options back [#17123506][#17124886] One reply points to firmware CR_ENEEUMF286V1.0.0B09 as the version to check against [#17123505] Another suggestion is to try SSH access with `root` / `zte9x15` and, if it works, modify the scripts manually [#17123866] The thread also links to MF286 information and setup material, but no one confirms a built-in menu for forcing bands or aggregation in the Orange firmware [#17123667] In short, the forum consensus is that this router/firmware likely does not support manual band selection from the normal settings, so enabling it would require a different firmware or deeper modification [#17123506][#17123866]
  • Missing LTE band selection after firmware update
    #1 17123353
    adrian92198
    Hello, I bought a ZTE MF 286 router from Orange today, which was praised for the ability to manually select the LTE band. The problem is that I downloaded the latest update, I did manual and software restart, and the band selection options are still missing. Anyone have any idea what's going on? I care about this because I wanted to test different bands and aggregation and then ask here for an external antenna :)
  • #3 17123506
    makosuu
    Help: 369
    Rate: 370
    From what I see, you can only select one band in this router. Enter the location, because it's hard to advise without it.
  • #4 17123598
    adrian92198
    This is how it looks, my location is on ul. Wiejska, Reguły, Michałowice commune
  • #6 17123866
    pitron
    Help: 51
    Rate: 100
    Try to connect to it after ssh like for example to MF823.
    root
    zte9x15
    If it succeeds, theoretically there is a chance to modify the scripts.
  • #7 17123957
    adrian92198
    This shows me something, I just don't know what it is supposed to help, in general I'm green in the subject and when I bought the router I was convinced that you can manually select the band and aggregate in the settings. There is an Orange card in the router.
  • #8 17124077
    matek451
    Help: 4352
    Rate: 5808
    Ask for no-wise and on what basis were you convinced about the possibility of choosing the LTE band? And the program showed a connection with LTE1800NetWorks with BTS Harcerska 30 in Piastów. Signal parameters are tragically weak. What speeds at them in the evening? Have you subscribed to Orange?
  • #9 17124653
    adrian92198
    I was convinced of this because they wrote on the manufacturer's website and Orange also. I took the subscription because I tested LTE in every network and it is one and the same, everything works mediocre for me, and in Orange although I do not have such speed drops as in T-Mobile. I have two weeks to terminate the contract, because ordered by phone. In the evening the speeds are very different, it can walk 1Mb / s, and moments later 8Mb / s.
    Anyway, I have the impression that these BTSs are somehow impaired near me, because it can jump like this even in hours when there is hardly any traffic.
  • #11 17124868
    adrian92198
    In Play, it's exactly the same, the worst thing that I mean best Plus, which has these senseless funnels after using 100GB, which is a misunderstanding
    Added after 6 [minutes]:
    In general, there is a misunderstanding. I live 10 km from the center of Warsaw, I do not have internet connection, because there are no telecommunications poles, I do not have 40Mb / 10Mb radios, because trees cover (300m from my home it is possible), and LTE is like those BTSs are 30 years old.
  • #12 17124884
    matek451
    Help: 4352
    Rate: 5808
    And what did these operator tests look like? You had the B529 with T-Mobile so you could check out the operator also Play and Plus, Orange forcing individual LTE bands and check CIDs, signal parameters and speed in each case. How did you check Play? Do you have three BTSs nearby with a set of LTE2600, LTE2100, LTE1800 and LTE800 and aggregation on each of the BTSs, several Mb / s band? You can see that you are blindly looking for the optimal operator. Have you forced the LTE2600 and LTE800 bands in Orange on the MF286?
  • #13 17124886
    adrian92198
    I will test these Orange on Huawei B593, because when I bought the Orange Free starter and tested it, I was better off now than this ZTE subscription.
    Added after 57 [seconds]:
    Well, the problem is that on this MF286 you can't change the bandwidth, but it was to be given and I do not know how to do it
    Added after 10 [minutes]:
    I put an Orange card in this B593 and I have 5/5 DL / UP at the same time as on ZTE 0.8 / 2, I suspect that this ZTE chooses some weird BTSs and bands, because it has 3 range lines and it goes much worse than this Huawei at 1 dash
    Added after 27 [minutes]:
    To make it even funnier, on this ZTE I achieve higher speeds on HSPA + than on LTE :)
The discussion revolves around the ZTE MF 286 router purchased from Orange, where the user is unable to access the expected LTE band selection options after a firmware update. Despite attempts to restart the device, the band selection remains unavailable, leading to concerns about testing different bands and aggregation capabilities. Responses indicate that the router may only allow selection of a single band, and suggestions include connecting via SSH for potential script modifications. The user expresses frustration over inconsistent internet speeds and the inability to manually select bands, which was a key feature they anticipated based on manufacturer claims. Comparisons with other routers, such as the Huawei B593, reveal better performance, suggesting that the ZTE router may be connecting to suboptimal base stations.
TL;DR: Expect occasional 1 Mb/s lows on congested LTE. "A subscription from DL to LTE at 1Mbps is a misunderstanding." This FAQ helps MF286 owners check bands/CA and stabilise Orange speeds. [Elektroda, matek451, post #17124714]
Why it matters: MF286 owners on Orange who lack band selection or see unstable LTE can test bands, evaluate BTS links, and choose antennas or operators.
After updating my Orange ZTE MF286, why is there no LTE band selection in the UI?
Orange’s branded MF286 firmware can omit the manual band selection page. In the reported case, updating and restarting did not restore it. That means you may need external tools or different hardware to test specific bands or CA behavior. [Elektroda, adrian92198, post #17123353]
What firmware build should I check on the MF286 from Orange?
Look for the firmware ID CR_ENEEUMF286V1.0.0B09 in your device information. Contributors referenced this Orange build when discussing features and missing band selection options. [Elektroda, matek451, post #17123505]
Can I manually aggregate bands (CA) or only lock one band on the MF286?
Users observed the MF286 UI allows only single-band selection. "You can only select one band in this router." Manual CA combo selection is not exposed in the interface. Any carrier aggregation happens automatically if the network offers it. [Elektroda, makosuu, post #17123506]
How do I read the current LTE band and BTS on the MF286?
Use the ZTE_MF286_Info v0.6.214 utility to query band, CID, and serving BTS. How-To: 1. Connect your PC to the MF286. 2. Run ZTE_MF286_Info and start a readout session. 3. Note the LTE band, eNB/CID, and BTS address for diagnosis and antenna planning. [Elektroda, matek451, post #17123667]
Can I SSH into the MF286 to tweak hidden settings?
Try SSH using credentials: root / zte9x15. If login works, you can access scripts and adjust advanced behavior. Changes are at your risk and may void support. Back up configurations before any edits. [Elektroda, pitron, post #17123866]
Which BTS am I connecting to near Regu2y/Micha2owice?
A shared readout showed an LTE1800 NetWorks cell from BTS Harcerska 30 in PiastF3w. The indicated signal parameters were very weak, which impacts stability and throughput. Consider testing other layers or improving signal before judging performance. [Elektroda, matek451, post #17124077]
Why are my evening speeds unstable (1ndash;8 Mb/s) on Orange LTE?
The author observed 1ndash;8 Mb/s swings in the evening around Regu2y. That pattern points to congestion and variable cell usage. Log your band/BTS, compare time windows, and test different layers to isolate the issue before changing plans or hardware. [Elektroda, adrian92198, post #17124653]
Is switching hardware worthwhile? What about Huawei B529/B593 for band locking?
Yes. A router like Huawei B529 lets you force individual LTE bands and read CIDs, streamlining operator and layer comparisons. Use such gear to test LTE2600/2100/1800/800 and observe CA availability around your location. [Elektroda, matek451, post #17124884]
Why does my older B593 get 5/5 while MF286 shows 0.8/2 at the same time?
Different device behavior can select different cells or bands. The user saw 5/5 Mb/s on a B593 versus 0.8/2 Mb/s on the MF286. That suggests cell selection or RF differences drive throughput, not only signal bars. Compare bands and BTS IDs during tests. [Elektroda, adrian92198, post #17124886]
Can HSPA+ really be faster than LTE on the MF286?
Yes. When the LTE layer is congested or unstable, HSPA+ can outperform LTE. The same user reported higher HSPA+ speeds than LTE on the MF286 under those conditions. Treat it as a congestion signal and reassess bands or BTS. [Elektroda, adrian92198, post #17124886]
Which operator should I choose near Regu2y for better LTE and CA?
Tests should include Orange, Play, and Plus. Nearby, multiple BTS reportedly offer LTE2600/2100/1800/800 with aggregation. Lock bands, log CIDs, and measure throughput on each layer to pick the most consistent operator. [Elektroda, matek451, post #17124884]
When should I add an external antenna to the MF286?
Add one if your serving cell shows weak signal, like the LTE1800 PiastF3w BTS case. Confirm the target BTS and band, then choose a matching directional antenna. Measure before purchase to avoid misalignment or band mismatch. [Elektroda, matek451, post #17124077]
Will reboots or resets restore band selection on Orange firmware?
Not in the shared case. After downloading the latest update and performing restarts, the MF286 still lacked band selection options. Plan on external tools or different hardware for controlled band testing. [Elektroda, adrian92198, post #17123353]
Can I force LTE2600 or LTE800 on the MF286 with an Orange SIM?
If your MF286 UI exposes single-band lock, you can select LTE2600 or LTE800 for testing. If it does not, use a router that supports band locking to compare layers and cells reliably. [Elektroda, matek451, post #17124884]
