[Solved] ZTE MF283+ Router Update 2021: Orange CR_ORAMF283+V1.0.0B08, Firmware BD_ZM8630V1.0.0B12, Solutions
da1k1 17379 9
How can I update a ZTE MF283+ Orange router from CR_ORAMF283+V1.0.0B04 when the router says no update is available?
You can update it manually: one user successfully flashed CR_ORAMF283+V1.0.0B07, and there is also CR_ORAMF283+V1.0.0B08 with WPA2 security fixes [#19389856] The firmware was not obtained through the router’s OTA updater; instead, it was linked under a YouTube video and had to be uploaded via TFTP [#19389856][#19864095] After the update, the earlier hangs stopped and band forcing worked again, so the router became usable [#19389856][#19864095] The OTA check on both Play and Orange SIMs still returned “No new version found” or “Failure,” so the update does not appear to be offered online for this device [#19389856]
  • Seeking official ZTE MF283+ firmware update source
    #1 19378985
    da1k1
    Rate: 8
    I have a ZTE MF283+ router from Orange and it hangs from time to time. I've also read that with newer software I can force bandwidth. So I hope that after the update it would still be possible to use this router. Unfortunately, my soft "stopped" on the software version: CR_ORAMF283+V1.0.0B04 and firmware: BD_ZM8630V1.0.0B11, and the router claims that it does not see the update. I found that the latest software is CR_ORAMF283+V1.0.0B08 / firmware: BD_ZM8630V1.0.0B12.
    ZTE did not respond to my e-mail or Messenger, on the CDTI website they want PLN 130 for the update (which is the same or more than the router is worth). On the internet I found only on some website what they want a credit card number, so it also falls out. Does anyone know where to download the software or how to force ZTE in Warsaw to contact me ;) ? I read on another forum that someone took the router to them and picked it up a moment later (and that would also be a great option), but it was before the pandemic ...
  • #2 19379137
    entermen
    Level 32  
    Help: 139
    Rate: 133
    I have exactly the same router. And I didn't say what you wrote.
    I use an orange card and what operator do you use?
    How long does it hang after exactly?
    Have you done a hard reset?
  • #3 19379150
    roxio
    Help: 108
    Rate: 213
    Do you get an "Error checking for updates" message when checking for updates?
  • No update found on Play or Orange SIMs
    #4 19379264
    da1k1
    Rate: 8
    I have had the router since new and at the beginning it was fine in my opinion, but there were 2-3 connected devices. Now I wanted to use it in another place and there are already 6-7 devices using it at once. I use the router with the Play card (in the past and now). It hangs quite randomly sometimes even every 2-3 hours and sometimes once a day. I did a hard reset, but it didn't help.
    Added after 8 [minutes]:
    No, I got "No new version found"
    Now I checked on the Play card, I don't have Orange at hand, but I remember that some time ago I bought an Orange starter for a test and it didn't see the update either.
  • Different hardware versions may lack the update
    #5 19379966
    KOCUREK1970
    Help: 3860
    Rate: 5488
    There may not be a new firmware, because there may be different hardware versions of this modem/router - it's probably the version from the initial ones.
    That's how I read it now, the date of publication of the equipment appears 2015, 2016 - there is no update for sure, it's electro-junk without support in the world of electronics.
  • #6 19379978
    matek451
    Help: 4352
    Rate: 5808
    It is soft for other brands, available OTA only the Orange version does not update online. Previously, people updated by driving to ZTE Polska, but it's rather a game not worth the candle, it's a museum.
  • MF283V compared with MF283+ for replacement
    #7 19380140
    da1k1
    Rate: 8
    I have hardware version no.1 PCBMF283+V1.0.0 I know it's museum equipment :) it was almost as good as I got it for PLN 1. However, I wanted to give this router some more time to live :) In normal times, I would probably drive to ZTE because it's not far away, but now I wanted to ask them first if there is anyone in the office at all. Unless I'm going to eat something tomorrow...
    By the way, I found that the router has Openwrt version snap shot (probably not suitable for everyday use, but someone had to go to great lengths to get Openwrt to work).
    I would love to buy a Huawei B535 from the outlet from them, but unfortunately it is not available now. It is now in Play ZTE MF283V, new for PLN 249. Is it newer/better than the MF283+?
  • Firmware update available via TFTP upload
    #8 19389856
    da1k1
    Rate: 8
    I found and more importantly I successfully updated to CR_ORAMF283+V1.0.0B07. There is also a version CR_ORAMF283+V1.0.0B08 which includes WPA2 security fixes. In the Play tab again I have "No new version found". Out of curiosity, I bought an Orange starter, hoping that it would download an update from Orange. And here, surprise, the message "Failure" appears ... does it mean that Orange has disowned this router?
    EDIT: After the update, the old problems with the router ceased to exist, I haven't tracked down the new ones yet, I managed to force the band, the router works decently. If anyone needs it, I have the firmware for this ZTE, I can share information where to look for it :)
    EDIT 2: Under this link there is a movie :) And under the video there is a link to the software. It needs to be uploaded via TFTP.
  • #9 19717970
    RamonG
    Thanks for this post da1k1, it was very useful to me :)
    Also stuck with firmware version CR_ORAMF283 V1.0.0B04. This version was sufficient with the ORANGE SIM card; but when I tested the PLAY card, I also encountered random disconnections. EDIT 2 link is a bit exotic but I managed to update to CR_ORAMF283 V1.0.0B07
  • TFTP firmware upgrade to CR_ORAMF283+V1.0.0B08
    #10 19864095
    da1k1
    Rate: 8
    I found and, more importantly, successfully upgraded to version CR_ORAMF283+V1.0.0B07. There is also a version CR_ORAMF283+V1.0.0B08, which is the one with the WPA2 security fixes. On the Play card I have again that "No new version found". Out of curiosity I bought an Orange starter hoping that it would download the update from Orange. And here surprise the message "Failure" appears ... Does this mean that Orange has disowned this router?
    EDIT: After the update the old problems with the router ceased to exist, I have not yet traced new ones, the bandwidth I managed to force, the router works decently. If someone needs, I have firmware for this ZTE then I can share the information, where to look for it :)
    EDIT 2: Under this link: https://youtu.be/GM4SJy3cYhQ there is a video :) And under the video a link to the software. It has to be uploaded via TFTP.
The discussion revolves around issues faced by users of the ZTE MF283+ router, particularly concerning firmware updates and performance problems. Users report that the router frequently hangs, especially when multiple devices are connected. The main user seeks to update from an outdated firmware version (CR_ORAMF283+V1.0.0B04) to the latest (CR_ORAMF283+V1.0.0B08) but encounters difficulties in finding the update. Some users suggest that the lack of updates may be due to different hardware versions and that the router is considered outdated. A few users successfully updated their routers to CR_ORAMF283+V1.0.0B07, which resolved previous issues. They also mention the possibility of using TFTP for firmware updates and share links to resources for obtaining the firmware. The conversation highlights the challenges of obtaining support and updates for older devices in the current market.
