Flooded xiaomi redmi note 4 - The phone does not charge when it is turned on
radekls529 5721 4
  • #1 17140530
    radekls529
    Hello, sorry if I chose the wrong section.
    To the point, I have a xiaomi redmi note 4 phone, it was shattered (not important) but after that it fell into the water and after this incident the display spilled (maybe it did not spill, but there were stripes on it, it is normally readable in full), but works, but the problem appears when charging, when the phone is turned on, it does not detect the charger or connection to the computer, but when I turn off the phone, it behaves like a discharged one, detects the charger, the charging icon appears and the process continues, while after turning on the phone again it stops detecting the charger, can it be saved somehow?
    nutergsm
    Help: 1034
    Rate: 1665
    You had to start with this, since the phone is flooded: https://www.elektroda.pl/rtvforum/topic1273413.html
    In addition, it is still after the fall, so it's a difficult matter. it would fit to go to the website and ask for a diagnosis.
  • #3 17140913
    radekls529
    I mean, the strikte phone works, it cracked in the morning and worked normally, all functions, it drowned in the evening ... only the only drawback that he has left is charging, how much can it cost? Thank you very much
  • #4 17141375
    nutergsm
    Help: 1034
    Rate: 1665
    Then you have to ask local services because everyone has their own prices.
  • #5 19376141
    dorota2302
    I have the same problem with the flooded xiaomi mi note 10. There is still a chance to find out if the phone was repaired? :)
