[Solved] Beko CSE52320 Oven Issue: No Heat, Function Switch & Lamp Fail - Clock & Gas Lighter OK
bodzio 5711 11142 2
  • #1 17143490
    bodzio 5711
    The oven's oven does not turn on, i.e. it does not heat the oven heater and the oven lamp does not light in the whole range of function switch settings. However, the clock and gas lighter work flawlessly.
    zadam64
    Help: 552
    Rate: 738
    I suspect damage to the function switch in the attachment, but you also need to check and measure the wiring in the oven from the connection.
  • #3 17154423
    bodzio 5711
    Thanks to "zadam64" - your diagnosis was correct, after replacing the function switch the oven works fine.
