Beko CSE 52620 Gas-Electric Cooker: Oven Breakdown, Temperature Knob Issues, & Light Not Turning On
thor_ 6567 7
  • Initial checks for oven light and selector switch faults
    #1 16682779
    thor_
    Rate: 13
    Gas-electric cooker BEKO CSE 52620 D
    The oven broke down a few days ago. At the moment, the symptoms are as follows:
    By turning the temperature knob, at the very beginning of the movement you can hear the sound of switching on / switching on, soft and again audible when turning the knob to the "zero" position, the oven light does not turn on.
    After setting the temperature with the right knob, when turning the left knob, whether to the right or left, when jumping to the first position, the light next to the temperature knob lights up but goes out immediately. You can slowly turn to "catch" the place where it lights up and by holding the knob in this place "keep" the lit temperature indicator. After switching to any of the positions, i.e. hot air, heating down, heating up, heating down + up, etc., you can still hear the fan, which normally always turned on after the oven was finished.
    The clock is set to the correct time.
    Please direct where and what to check first
    The rest of the oven works OK.
    • WP_20170905_18_06_50_Pro.mp4 (61.85 MB) You must be logged in to download this attachment.
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2661
    The suspect is: Link .
    mrx2000
    Help: 21
    Rate: 47
    The most suspicious oven mode selector (left knob).
    Maybe it's this one, but ask in the store:
    https://north.pl/karta/przelacznik-funkcji-beko--263100032-,60Z-LS-ZL2D-0ZM.html
    You'd have to go and check with a pass meter. Try one of the modes briefly.
    When you undress, you will probably see what and how.
    Edition:
    I can see that a colleague above found the right model faster :)
  • #4 16682965
    pszczyna
    Help: 214
    Rate: 404
    Well, good luck because I have been unable to ask the BEKO service for repairing the washing machine for 15 days, despite the daily calls
  • #5 16682977
    MARCIN.SLASK
    Help: 1037
    Rate: 2661
    Not this website is different. Unless it's under warranty.
  • #6 16683046
    thor_
    Rate: 13
    Thank ;) for days I will take the stove apart and see what and how. There is nothing to dream about the warranty service because it is a fault of the "right after the warranty" ;)
    I will let you know what and how, because I will probably need some tips or help ;)
  • #7 16727763
    thor_
    Rate: 13
    I did not speak for a long time because somehow it turned out ;)
    In any case, the oven works for now, in fact the problem was the "oven mode selector" - thanks to MARCIN.SLASK and mrx2000.
    I undressed, looked at it, disconnected, checked the passage and it's okay ... but after a closer look it turned out that the penultimate "bridge" is getting cut. More precisely, this element on the spring, after the pressure was released on it by the protruding element on the axis of the "divider", the spring did not push it out enough to reach the connection. Besides, this protruding "selector" on the shaft on this very "bridge" is clearly worn / worn out, as if it had to force its way through it with some greater force. Or maybe melted from temperature, in total the color of this "bridge" seems to be more "warmed".
    In any case, it works for the moment and if it sprinkles again, this time I will replace it with a new one.
  • #8 21499954
    Tomasz Sz
    Old topic but maybe someone can tell me how to replace this selector?
    On the underside of the button panel there are two moles which are not a problem but on the top something is holding.
    How do you unscrew it? Do you have to remove the top with the burners?
The BEKO CSE 52620 gas-electric cooker oven experienced a malfunction characterized by the temperature knob producing switching sounds at the start and return to zero, the oven light failing to turn on, and the mode selector knob causing the temperature indicator light to flicker and only stay lit when held in a specific position. The oven fan continued to operate normally after use. Investigation identified the oven mode selector switch (left knob) as the likely fault. Upon disassembly, the mode selector was found to have a worn and partially melted contact bridge on a spring mechanism, causing intermittent electrical connection failure. The worn selector shaft and heat damage to the contact bridge explained the erratic behavior. The oven currently functions by carefully positioning the knob, but replacement of the mode selector switch is recommended to restore reliable operation. Additional queries addressed the physical removal of the selector switch from the control panel, noting retention clips and screws under the button panel and possible need to remove the burner top for access.
