Brotje Energy Top 24CE Oven: Not Heating Despite Displaying Set Temperature
tygrys88 12144 3
  • #1 16757742
    tygrys88
    Hello. I have a problem with the Brotje Energy Top 24CE oven. Today, he simply stopped warming. The set temperature on the stove was 55 C. I was just sitting on the radiator watching TV and I started to feel that the temperature was falling. After going down to the basement, I saw that the stove only shows the temperature but does not work. No error popped up (which could help). I tried to reset and disconnected from the power supply for several minutes. No effect. After switching it on again, the stove does not start, it only shows the temperature.
    Has anyone had a similar problem?
    Regards.
  • #2 16843949
    Beny94
    Rate: 26
    Hello, I have the same problem from today. The stove does not ignite the spark and it does not heat at all. I only show the temperature that keeps falling down ... And it is cold quite outside and the nights are cold so I would ask for some reaction if anyone had a similar problem and cope with it or need a new stove buy?
  • #3 16844528
    zybie
    Level 30  
    Help: 133
    Rate: 754
    You have a thermostat installed and what temperature you have set on the boiler.
  • #4 16845428
    Beny94
    Rate: 26
    Yes, I have it and it is set at 20 degrees, because such a temperature is enough for me on the stove is set so that they warm up to 56 degrees, but the stove does not respond. The water temperature is already turned on 15 degrees. that is, it should be fired a long time ago and nothing reacts here the thermostat works because it was snapped and the spark should ignite
