[Solved] Low Pressure in Junkers Boiler: No Hot Water, How to Increase Pressure & Add Water (Photos)
Laik2018 16866 7
  • #1 17144451
    Laik2018
    Rate: 15
    Hello, I am a layman. Boiler pressure very low. How to pick them up. Add water? Photos included. Thank you in advance.
    • Low Pressure in Junkers Boiler: No Hot Water, How to Increase Pressure & Add Water (Photos) IMG_20180402_153532.jpg (3.48 MB) You must be logged in to download this attachment.
    • Low Pressure in Junkers Boiler: No Hot Water, How to Increase Pressure & Add Water (Photos) IMG_20180402_153514.jpg (3.17 MB) You must be logged in to download this attachment.
    sp3ots
    Help: 524
    Rate: 674
    Hello !
    Try adding more water with the blue knob.
    arturdip
    Help: 170
    Rate: 324
    The pressure is too low, but adding water can be a half-measure. You should find a place where it is depleting (maybe no one ever let water in and it slowly flowed out somewhere, then it makes sense to top up with water) pos artur
  • #4 17144523
    Laik2018
    Rate: 15
    Hello. Turn off all installations before this?
    arturdip
    Help: 170
    Rate: 324
    You can, but there is no need for it (just to admit water)
    serwisszulborski.pl
    Heating systems specialist
    Help: 360
    Rate: 1448
    Turn the blue knob anti-clockwise until you hear water flowing in. The pressure on the manometer should be about 1.5 bar, tighten the choke. Continue looking for moisture in the installation. Check the screw connections and the breather. Below 1 bar, do not use a junker because you will stop the pump and it costs about PLN 1000. The boiler is not protected against water loss, so you need to take care not to damage the device.
  • #7 17144931
    Laik2018
    Rate: 15
    Thanks all. Junkers recovered :-)
    • Low Pressure in Junkers Boiler: No Hot Water, How to Increase Pressure & Add Water (Photos) IMG_20180402_201456.jpg (3.61 MB) You must be logged in to download this attachment.
  • #8 17145011
    Laik2018
    Rate: 15
    Topping up water and increasing the pressure.
The discussion revolves around addressing low pressure issues in a Junkers boiler, which results in a lack of hot water. Users suggest adding water through a blue knob to increase pressure, ideally to around 1.5 bar. It is advised to check for leaks or moisture in the system, as continuous water loss can lead to further problems. Turning off installations before adding water is not necessary, but caution is recommended to avoid damaging the boiler. The author confirms successful recovery of the boiler pressure after following the advice.
