[Solved] Acer Nitro 5: Solve EFI Shell Issue & Disable – Keep Files After System Updates
Chyczevzky 21117 9
How can I get an Acer Nitro 5 out of EFI Shell after updates, and will my files on the disks still be there?
Your files may still be on the disk, but the first thing to check is the BIOS/UEFI BOOT tab and make sure the laptop is trying to boot from the internal drive, not EFI Shell; on Acer laptops this is usually entered with Del or via the boot menu with F12 [#19231133][#19231534][#19236439] If you cannot get into BIOS because of a password, the thread suggests the practical option is to remove the drive, connect it to another computer to copy the important files, and then reinstall the system from a USB stick or use Acer recovery, which will erase data [#19236625][#19236685]
  • EFI shell screen after system update needs boot repair
    #1 19230432
    Chyczevzky
    Level 4  
    I'll admit right away that I know absolutely nothing about computers. Some system updates etc have been done on my Acer Nitro 5 laptop. After turning on the laptop, this screen is shown. I don't know what to do next. Is the system still where it was and is everything that was on the disks still there? Please help me quickly!
  • #3 19231495
    Chyczevzky
    Level 4  
    And how could I get in there, any commands to enter?
  • #4 19231534
    sosarek
    Help: 9320
    Rate: 15532
    With even the DEL key? When the laptop starts up, it shows Press... to enter Setup/BIOS/UEFI...
    Z
    Pka, Poznań, 60-850
  • #5 19236310
    Chyczevzky
    Level 4  
    I need a password to enter the bios, but I don't know what it is. There are some generators of these passwords but I don't trust them too much.
    Added after 25 [minutes]:
    I have one more question, should I do this? Refreshing the system by turning the laptop on and off. Would this help me and would the laptop then turn on normally, i.e. straight to windows?
  • #6 19236439
    safbot1st
    Help: 2719
    Rate: 1585
    You mean reset BIOS settings? I don't think anything here will help.
    EDIT.
    Did you have a BIOS password already set up?
    Does the F12 key (boot menu call) work?
    Do you remember exactly that update that damaged your computer?
    Was it a BIOS update?
  • #7 19236601
    Chyczevzky
    Level 4  
    I don't remember these updates anymore. I talked to a friend who knows a bit about this and he said that this update kicked the startup files from the system. And even refreshing the system, i.e. I wrote earlier, nothing can be done because it simply does not fire.
  • Acer recovery requires data loss after EFI failure
    #8 19236625
    safbot1st
    Help: 2719
    Rate: 1585
    Agreement. Booting the system does not work, but where did the BIOS password come from?
    I found a solution but it's hopeless.
    There are threads online with the same problem.
    One guy ripped his important files from a hard drive somewhere to another computer.
    Disk physically disconnected from the 'broken' pc and connected to another.
    After rescuing the data, he performed a 'system restore with data loss' using Acer's built-in recovery.
    So actually the so-called 'format c:'.
    The worst possible solution. Probably different,
    the only question is how much faster...
  • #9 19236681
    Chyczevzky
    Level 4  
    Well, thank you anyway for the response, I close the post, and rather put a new system from the flash drive.
  • #10 19236685
    Chyczevzky
    Level 4  
    Setting up, repair using a system downloaded to a flash drive.
The discussion revolves around an Acer Nitro 5 laptop that is encountering an EFI Shell issue after system updates. The user is uncertain about accessing the BIOS/UEFI settings due to a password requirement and is concerned about data loss. Responses suggest checking the BIOS settings and using the F12 key for the boot menu. A potential solution involves disconnecting the hard drive to recover important files before performing a system restore, which may result in data loss. Ultimately, the user decides to install a new operating system from a flash drive as a resolution.
