Volvo FH 460EEV 2011 Skirt: Deciphering MID 128 PPID8 FMI2 Error - Cooling System Pressure
volvo fh460eev 22398 2
  • #1 16624375
    volvo fh460eev
    Rate: 36
    Hello colleagues, can anyone decipher the MID 128 PPID8 FMI2 error (cooling system pressure - data error)?
    It appears when I drive at maximum speed.
    Oil condition OK, temperature does not exceed 120 degrees. Coolant condition normal, computer temperature 60-75 degrees.
  • #3 16625943
    volvo fh460eev
    Rate: 36
    I will add that I observed the oil pressure indicator. At a standstill it can fall almost to zero and while driving does not exceed half the scale then an error occurs. Sometimes it is normal, i.e. when the indicator is at a level of 1/4 and while driving can "get out" in half. Is this enough to tell you that the fault lies with the oil pressure sensor? Volvo has invaded 770,000
