Junkers WRP 11: How to Adjust Knobs for Warmest Water - Troubleshooting & Expert Advice
Amber22 10860 3
  • #1 17175062
    Amber22
    Good morning, could someone more knowledgeable tell me how to turn these knobs to make the water warmest? Unfortunately, something appeared in the junkers and summer flies ...
    thanks for the help in advance
    • Junkers WRP 11: How to Adjust Knobs for Warmest Water - Troubleshooting & Expert Advice IMG_20180418_173445.jpg (1.53 MB) You must be logged in to download this attachment.
  • #2 17175073
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    Left (gas) maximally to the left (but this will cause high gas consumption, as there will be a large flame) and right - maximally to the right (then the smallest stream of water, but HOT). Note: with the setting as I wrote, the water can be very hot (it can seriously burn), so it is better to reduce the gas with the left knob (to the smallest possible).
  • #3 17175618
    Amber22
    Thank you for your answer. Unfortunately, in this device it is impossible to turn the knob to the max, because you can rotate it endlessly :) how best to set these "arrows"?
  • #4 17175680
