Nbox BSKA ITI-5800S Decoder Issues: No Response, Swollen Capacitors & Display Not Lighting Up
rsobczynski83 7596 3
  • #1 17190854
    rsobczynski83
    Hello everyone, I have the NKA BSKA ITI5800S Decoder, it stopped working about two weeks ago. When switched on, only SPDIF was lit. After dismantling the decoder in the power supply system were swollen capacitors that I replaced and 4x 470uf and also replaced one 1500 uf which was damaged and two that were not damaged i.e. 1000uf. When you turn it on again, nothing lights up on the display. The power supply checked because I have a second such a decoder and the second one works without a problem. What else can I do that I will add that the decoder had enigme2 installed and there is no A19 and A20 jumper on the board. Is the display fell the rest of the capacitors on the head also looks ok. Maybe someone can do something else I can do I was thinking about replacing the display but will it help if there is no jumper on the board at all, maybe the decoder is already to be thrown ???
    Thank you for your help. Regards.
  • #2 17195544
    simhak
    Help: 109
    Rate: 336
    In order to verify the "jumpers" you need to lift the disc, it is possible that they are not "pulled" to the top. The glue was "scratched", can you see the memory?
  • #3 17195639
    rsobczynski83
    Yes, the glue was scratched, you can see the memory and I found the jumper underneath, someone can advise you what to do is connected under the A20, now I will add a photo
    • Nbox BSKA ITI-5800S Decoder Issues: No Response, Swollen Capacitors & Display Not Lighting Up 1525101110978-635046574.jpg (3.6 MB) You must be logged in to download this attachment.
    • Nbox BSKA ITI-5800S Decoder Issues: No Response, Swollen Capacitors & Display Not Lighting Up 1525099781626-640084400.jpg (3.59 MB) You must be logged in to download this attachment.
  • Display dead after capacitor replacement, suspecting board fault
    #4 17701642
    loloslol
    Hi, I have a question - did you find a solution? Decoder moved or went to the trash? I am asking because exactly the same thing happened to me, the decoder does not start, the optical output is on, the display is dead.
    best regards
