[Solved] Nbox ITI-2850st Tuner: Powers On, Displays Start Image then Shuts Off Before Activation Screen
bitters 6240 5
  • #1 16277814
    bitters
    Rate: 41
    Hello. I have a problem with my nc + tuner, namely after switching on, the start image is shown, a moment later it goes into the start image in HD format and after a while it turns off without showing the activation screen. Please help, maybe someone will suggest something, where to start.
  • #2 16277869
    andpol 33
    Help: 514
    Rate: 1147
    Check what resolution is set in the decoder. What cable is connected to the tv?
  • #3 16278082
    bitters
    Rate: 41
    HDMI cable, it's definitely not about the resolution, it's set to 100% right, besides, it shows me a greeting in 1920x1080 resolution, but how to enter the activation screen, where is the strength and quality of the signal, the tuner lights up red and that's it, I can't do anything with the remote do even though it is 100% functional
  • #4 16278218
    simhak
    Help: 109
    Rate: 336
    Change the decoder resolution or connect with a SCART cable.
  • #5 16278464
    andpol 33
    Help: 514
    Rate: 1147
    Press the star 3 on the remote control.
  • #6 19007494
    bitters
    Rate: 41
    Ok, everything is fine, restarted the button combination 2 times red then 73738. Regards and thanks for your interest
