LG OLED 65C8 test - the king has died, long live the king. We create history, i.
4332 5
  • LG C8 OLED review highlights Alpha 9 processing and HFR
    #1 17192118
  • Critique of AI-driven TV personalization and data use
    #2 17192288
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    The TV should be used for viewing. All these AIs are probably intended for the viewer to choose programs with content that is supposed to suggest something (see the scandal with the facebook data).
    Unfortunately, I associate it with this. On the hardware side, I do not think that the AI on the TV set the image parameters better than the user (each of us is different, and each sets according to their preferences / requirements).
    And so the world and producers strive to make the viewer a customer. Customer. I was a buyer and seller. The buyer of ads and products, and the seller of their data. One more moment
    and the TV will not work without access to the network (internet).
  • #3 17192607
  • #4 17192836
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    It is good that there is 4k and oled, the rest is silent.
    I have been waiting for TV for 20 years which will radiate smells based on the picture.
    I watch Star Wars and smell the cosmos, watch bar atmosphere and feel the smoke of cigarettes and typing breath from the screen after 20 lines.
  • #5 17195279
    pikarel
    Help: 410
    Rate: 1852
    Why do I need to watch satellite or terrestrial TV (without internet access)
    Do you need equipment with 200Hz refresh rate (in marketing gibber, called PMI, even 600), if 50Hz is interpolated everywhere in the message (i.e. 25 images spread over 50 half images)?
    This is no longer in your dissertation.
    As a side note, I would like to add that in order to fully appreciate the work of film producers and watch the match normally - all improvers should be turned off available in the TV menu, especially all "moszszyny" and "picztery".
    Why?
    Because what is necessary for the proper operation of each matrix, also OLED - is already stitched in the matrix driver (called LCD in the T-CON), set for a specific model in the production phase, then available only in the service mode.
    I'm interested in the native matrix refresh rate (50 or 100 Hz), not marketing wonders; you just set the image parameters by adjusting the contrast and brightness to get the full range of gray levels in the image, and complete the settings with the degree of saturation and color temperature (which we like, cold, warm, natural):
    link
    And these settings do not depend on the type of image sensor, they are always set the same.
    The undoubted advantage of the TV with an OLED matrix is the identical - independent of the angle of looking at the screen - image, the same is the TV with a picture tube (CRT)
    and with a plasma matrix. Each LCD matrix falsifies colors when the angle of view is changed, but the higher the matrix generation (currently 8), the less color falsification.
    What I read in the first post - is it a new version of VooDoo?
    Such VideoVooDoo?
  • #6 17408766
