Renault Laguna 2 (2005) - Uploading Spolszczenie & Updating Maps for Ph2 Navigation System
bocher 12522 6
  • #1 16491889
    bocher
    I have Renault laguna 2 ph2 2005. I wanted to install it in crack and update maps. How can I do this. I will add that I can not unequivocally determine what kind of navigation because everywhere I read this update is based on the use of a CD reader in the clipboard, but I only have an ampitiuner there without a disc tray.
    Regards and I count on help.
  • #2 16492448
    kamiloskop
    Help: 42
    Rate: 279
    Give exactly the model of the winding or insert photo.
  • #3 16492562
    bocher
    I give pictures from the internet because now I'm at work and I do not have access to a car. Everything agrees 100%.
    Menu appearance:
    Front:
    This is in the clipboard:
    control:
  • #4 17269429
    trawqu
    Rate: 37
    This is Carminat Informe 2 DVD.
    The Pole is not for free ...
  • #5 18723258
    toney
    Rate: 8
    I also in this case, I have the same navigation, a request for help in starting.
    Best regards and waiting for the verse
  • #6 18723675
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    You insert a disc with a map and after work.
  • #7 18725073
    toney
    Rate: 8
    So only a new map? I checked on the Renault website after the vin number that the navigation system
    no update required.
The discussion revolves around updating the navigation system in a 2005 Renault Laguna 2 Phase 2 (PH2). The user seeks assistance in installing a cracked version of the navigation software and updating maps, noting the absence of a CD reader in their vehicle's setup. Responses clarify that the navigation system is the Carminat Informe 2 DVD, and suggest that map updates typically require inserting a disc. However, one user mentions that the Renault website indicates no updates are necessary for their navigation system based on the VIN number.
