3.5 inch HDD Case Design: Universal Dimensions & Screw Spacing for 4-6 Drives in Design Spark
sewek1000 5934 2
  • #1 17201938
    sewek1000
    Help: 17
    Rate: 26
    Hello, I have a problem, I plan to design a case for 4-6 HDD 3.5 HDDs in Design Spark and I need to determine what universal dimensions to use and mounting holes at what points are the dimensions, would anyone be able to help? thank you.
  • #3 17202022
    sewek1000
    Help: 17
    Rate: 26
    I was looking but I could not find, from the 3d model of another author's case to hdd I came out to build a thickness of 2.6 cm, length of 14 cm and width of 10.6 cm, I will compare it with pictures from the web, thank you for your help, I give thanks and I close the topic :)
