Maximum Number of Hard Drives or SSDs Supported by a Single Computer System
lamcpp 31989 4
  • #1 5177803
    lamcpp
    Rate: 18
    how many disks can be connected to one computer?
    I can see on the tapes that there are still free seats, but I have a strange feeling that there are only two
    someone managed to connect more so that everything flickered?
  • #2 5177806
    szaleniec
    Help: 476
    Rate: 199
    Yes.
  • #3 5177808
    lamcpp
    Rate: 18
    ie how many drives max?
  • #4 5177820
    pul69
    withe
    you know, it all depends on the motherboard.
    the most common configurations are 2xsata + 1x2 or 2x2 ata
    which means you can give 4/6 of the agreements
    of course, you can still connect a USB disk or, for example, buy an additional disk controller, so the number is not really limited, but in my humble opinion it is better to buy a larger disk.
    cheers 600
    pul69
  • Dual-channel PATA supports four devices; consider PCI SATA
    #5 5177861
    SP2UKP
    Help: 16
    Rate: 28
    Since
    lamcpp wrote:
    ... on the tapes I can see that there are still places available
    that is, a motherboard with a dual-channel PATA (Parallel ATA) controller.
    One tape for each channel, two devices for each tape (disk, PATA optical drive). One drive as master, the other as slave.
    It is worth remembering that the entire channel works only as fast as the slower of the two devices (it is not worth connecting the optical drive and the hard disk on one channel).
    When it comes to capacity and the computer will be replaced one day, it may be worth investing in a SATA (Serial ATA) controller for PCI and a larger SATA disk.
