Configuring Universal Remote Control for TV Box MXQ - Unresponsive to Commands
morfeusz007 13293 3
  • #1 17206470
    morfeusz007
    Hello, I have a problem with the TV Box remote, everything worked perfectly but I did not use it for a long time and now when I put the batteries in, the remote control works normally (the LED is on), but the TV Box does not respond at all. I think it is a universal remote control, but I don't have a code to program it.
    I am asking for some information, how can I configure it?
  • #2 17207551
    procsa
    Help: 173
    Rate: 364
    This is not a universal remote control, check the TV BOX socket from the IR, maybe something came up and contacts as needed (disconnects the internal sensor).
  • #3 18044050
    MastreDziku
    Rate: 24
    You must put the remote.conf file into the System / etc directory on the box. You must have Total Commander or ES File Explorer with ROOT. Then reboot the box and must work. CHECKED ON MY MXQ S805.
    • remote.zip (1.26 KB) You must be logged in to download this attachment.
  • #4 18654192
    300Przemoc
    madafakin lifesaver. thanks!
