Unwanted Page Autoload Issue in Google Chrome at System Start
kuku83 38430 8
  • #1 17214621
    kuku83
    Rate: 56
    Hello and welcome
    I have such a problem, at the start of the system, the Google Chrome browser automatically starts opening an unwanted page, unfortunately I am not very familiar with such matters, so I am asking you for help, for which I thank you in advance.
  • #2 17214631
    -Sullivan-
    Help: 5
    Rate: 15
    What operating system do you have?
  • #3 17214633
    kuku83
    Rate: 56
    Sorry forgot to write, Windows 10
  • #4 17214641
    -Sullivan-
    Help: 5
    Rate: 15
    Ctrl + Left Shift + Esc. The task manager will appear. Then click on the "Startup" tab. There you will see the processes that start with the system. Chrome browser should be listed. Right click and disable this process at system startup. Then go to the browser settings and there you will be able to set a specific page that will be activated when the browser is launched. Then reboot and it should be fine.
  • #5 17214651
    kuku83
    Rate: 56
    Only for me there is no google chrome in the launcher tab
  • #6 17214838
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Attach the required FRST logs instead of producing redundant posts!
  • #7 17215807
    kuku83
    Rate: 56
    I attach logs from FRST:
    • FRST.txt (63.52 KB) You must be logged in to download this attachment.
    • Addition.txt (58.58 KB) You must be logged in to download this attachment.
  • FRST fixlist removes malicious startup entries
    #8 17215908
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Obok frst.exe utworz plik Fixlist.txt z zawartoscia:
    CustomCLSID: HKU\S-1-5-21-3209872981-2662963630-1788199521-1001_Classes\CLSID\{1BF42E4C-4AF4-4CFD-A1A0-CF2960B8F63E}\InprocServer32 -> C:\Users\kuku0\AppData\Local\Microsoft\OneDrive\18.044.0301.0006\amd64\FileSyncShell64.dll => Brak pliku
    CustomCLSID: HKU\S-1-5-21-3209872981-2662963630-1788199521-1001_Classes\CLSID\{7AFDFDDB-F914-11E4-8377-6C3BE50D980C}\InprocServer32 -> C:\Users\kuku0\AppData\Local\Microsoft\OneDrive\18.044.0301.0006\amd64\FileSyncShell64.dll => Brak pliku
    CustomCLSID: HKU\S-1-5-21-3209872981-2662963630-1788199521-1001_Classes\CLSID\{82CA8DE3-01AD-4CEA-9D75-BE4C51810A9E}\InprocServer32 -> C:\Users\kuku0\AppData\Local\Microsoft\OneDrive\18.044.0301.0006\amd64\FileSyncShell64.dll => Brak pliku
    Task: {9940DBEF-AC8D-402F-A743-ADB86AB78CDF} - \FreeDownloadManagerNetworkMonitor -> Brak pliku cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v Anna /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" explorer.exe hxxp://exinariuminix.info {13D67BB7-DB5F-48AA-884D-7A5D94168509} -> Brak pliku
    BHO-x32: Brak nazwy -> {13D67BB7-DB5F-48AA-884D-7A5D94168509} -> Brak pliku
    CHR HKU\S-1-5-21-3209872981-2662963630-1788199521-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [lmjegmlicamnimmfhcmpkclmigmmcbeh] - hxxps://clients2.google.com/service/update2/crx
    2018-05-10 08:15 - 2018-05-10 08:16 - 000000000 ____D C:\AdwCleaner
    2018-05-10 08:13 - 2018-05-10 08:13 - 000000000 ____D C:\Users\kuku0\AppData\Local\AdAwareUpdater
    2018-05-10 08:13 - 2018-05-10 08:13 - 000000000 ____D C:\Program Files\Common Files\adaware
    2018-05-10 08:12 - 2018-05-10 08:12 - 000000000 ____D C:\ProgramData\adaware
    W FRST wybierz Napraw.
    Usun katalog C:\FRST i to wszystko.
  • #9 17215967
    kuku83
    Rate: 56
    So yes, I created a txt file on the desktop where I have FRST with the content I was supposed to paste and it's ok
    Thank you for your help and best regards.
The discussion revolves around an issue where Google Chrome automatically opens an unwanted page upon system startup on a Windows 10 operating system. Users suggest checking the Task Manager's "Startup" tab to disable Chrome from launching at startup. If Chrome is not listed, further troubleshooting is recommended, including analyzing logs from the FRST tool to identify potential malware or unwanted processes. The user successfully created a Fixlist.txt file to address the issue, indicating progress towards a solution.
