How can I fix Google Chrome so it closes immediately after I launch it?
Uninstall Chrome, delete the browser profile folder `C:\Users\Master\AppData\Local\Google\Chrome\User Data\Default`, and then reinstall Chrome; this may stop the immediate shutdown on startup [#17441678][#17441784] Deleting that profile folder will remove saved passwords, bookmarks, and other Chrome data [#17441784] Earlier cleanup steps in the thread included removing McAfee WebAdvisor and YTD Video Downloader, running FRST/AdwCleaner/Malwarebytes, and checking the disk SMART status, but those did not solve the problem here [#17440616][#17440476][#17441570]
I did everything as you ordered, but unfortunately it did not help. I am sure that I did everything right. And as for the disk I know it is damaged because we once detected another topic also through SMART analysis. Soon I will look for some other disk. I know that it can fall in any I'm aware of this moment.
I did not know that the disk can affect the operation of the browser since previously, despite its damage, everything worked. But thanks for your help anyway. In general, I must seriously consider changing the disk in the near future.
Google Chrome is experiencing immediate shutdowns upon launch, preventing the user from interacting with the browser. Initial suggestions included closing the browser before shutting down the computer, but the user reported being unable to do so. Further troubleshooting involved checking if other browsers function correctly, downloading the Farbar Recovery Scan Tool (FRST) for system diagnostics, and examining the disk's SMART status using Crystal Disk Info. The user was advised to uninstall problematic software and potentially reinstall Chrome after deleting the browser profile directory. Ultimately, the user confirmed that deleting the profile directory resolved the issue, although they acknowledged a damaged disk that may require replacement. AI summary based on the discussion. May contain errors.
TL;DR: Chrome closes on launch? One profile directory reset is the recommended fix here. "You can uninstall Chrome, delete the browser profile directory and reinstall it." [Elektroda, Kolobos, post #17441678]
Why it matters: This FAQ helps Windows users fix Chrome that shuts down immediately after starting, fast and safely.
Chrome profile path: C:\Users\\AppData\Local\Google\Chrome\User Data\Default; deleting it erases saved passwords, bookmarks, and settings. [Elektroda, Kolobos, post #17441784]
How do I fix "Chrome closes immediately after opening" on Windows?
Use the expert’s fix: uninstall Chrome, delete its profile folder, then reinstall Chrome. “You can uninstall Chrome, delete the browser profile directory and reinstall it, it may start.”
Uninstall Google Chrome from Windows Apps/Programs.
Delete the Chrome user profile folder (see next question for the path).
Where is the Chrome profile folder (User Data\Default), and what do I lose?
Path: C:\Users\\AppData\Local\Google\Chrome\User Data\Default. Deleting it removes saved passwords, bookmarks, and other settings. Ensure you accept that data loss before proceeding. The helper explicitly warned of this consequence when providing the path. [Elektroda, Kolobos, post #17441784]
I can’t click Chrome — it freezes and vanishes. What should I do?
You don’t need to click inside Chrome. Use Windows to uninstall Chrome. Then delete the browser profile folder via File Explorer. Reinstall Chrome afterward. This bypasses the unresponsive window entirely. [Elektroda, Kolobos, post #17441678]
Should I check my hard drive’s SMART if Chrome keeps crashing?
Yes. The helper noticed disk issues in logs and asked for a SMART check. Use CrystalDiskInfo to read SMART and share a full-window screenshot so all parameters are visible. This helps rule out storage-related instability. [Elektroda, icosie, post #17440476]
Was malware involved in this case?
Yes. An expert noted, “You also had an infected system …” Clean the system first, then retest Chrome stability. Removing adware and malware reduces interference with browsers and startup behavior. [Elektroda, Kolobos, post #17441599]
What cleanup tools should I run to remove adware/malware?
Run AdwCleaner first (Scan/Szukaj, then Clean/Usun), then a full Malwarebytes scan and remove what it detects. Apply the FRST Fixlist if you were given one, and remove the C:\FRST folder afterward. “Uzyj AdwCleaner, opcja Scan/Szukaj i Clean/Usun.” [Elektroda, Kolobos, post #17440616]
Which add-ons or programs should I remove to stabilize Chrome?
Remove two items: McAfee WebAdvisor and YTD Video Downloader. The expert asked to uninstall both as part of cleanup. Doing so eliminates browser hooks and extra services that can impact stability. Uninstall them via Programs and Features. [Elektroda, Kolobos, post #17440616]
What logs does FRST create, and why were they requested?
FRST generates two logs: FRST.txt and Addition.txt. The helper asked you to attach both so specialists can review and route your case correctly. These diagnostics guide targeted fixes rather than guesswork. [Elektroda, icosie, post #17440301]
Should I test another browser to isolate the issue?
Yes. Try another browser such as Internet Explorer. If it works, the fault is likely Chrome-specific. If all browsers fail, suspect system-wide issues that require broader troubleshooting. [Elektroda, icosie, post #17440301]
Do I need to close Chrome before shutting down Windows?
Yes. Close the Chrome window before turning off the computer. This simple habit can avoid session hiccups that complicate diagnosis. It was recommended early in the thread. [Elektroda, TvWidget, post #17440084]
It still crashes after cleanup — what’s the likely edge case?
A damaged drive can undermine software fixes. The OP confirmed disk damage and noted previous SMART warnings. In this edge case, replace the failing disk to restore overall stability, then reinstall Chrome. [Elektroda, BladeMasterPL, post #17441570]
Did the steps ultimately work for the original poster?
Yes. The OP later wrote, “It helped a lot thanks,” and closed the topic. That confirms the issue was resolved after following the guidance provided in the thread. [Elektroda, BladeMasterPL, post #17626842]
