[Solved] Windows 10 Trojan Infections: Win32/Fuerboos.C!cl, Win32/Occamy.C, Trojan.Eps.38782 and More
Wladyslaw666 4143 8
  • #1 17221426
    Wladyslaw666
    Please check the logs.
    Every time Dr.Web CureIt! finds something. Malwarebytes sometimes finds something and sometimes shows it's clean. Windows defender occasionally shows that it has found a threat such as:
    - Trojan.Eps.38782
    - Trojan: Win32 / Fuerboos.C! Cl
    - Trojan: Win32 / Occamy.C
    - Trojan: Win32 / Woreflint.A! Cl
    - Trojan: Win32 / Emelent.B! Cl
    - Trojan.WebPick9115
    Often, before the end of the scan with any program, the message "The computer has encountered a problem and needs to be restarted" pops up.
    • Addition_15-05-2018 09.23.11.txt (69.26 KB) You must be logged in to download this attachment.
    • FRST_15-05-2018 09.23.11.txt (93.42 KB) You must be logged in to download this attachment.
  • #2 17221656
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Utworz punkt przywracania systemu.
    Odinstaluj NarutoOnline 2.4.1.5251
    Wykonaj Fixlist.txt dla FRST:
    CloseProcesses:
    CustomCLSID: HKU\S-1-5-21-3872729047-4223950186-2412060388-1001_Classes\CLSID\{cece6816-6107-4dc7-bdbc-20cd5ae1ffed}\localserver32 -> C:\ProgramData\Lenovo\ImController\Plugins\LenovoAppPromotionPlugin\x64\DesktopToastsHelper.exe => Brak pliku
    ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => -> Brak pliku
    Task: {8C965156-17C8-40B0-A65B-7BC5CAD98FEB} - System32\Tasks\MainPM => powershell -ExecutionPolicy ByPass -File pm.ps1
    Task: {DC1CA028-21DC-480C-9DBD-DE4FE42D10D2} - System32\Tasks\update64 => C:\Program Files\SystemaRev\RevServicesX\updaterev.exe [2018-05-14] (SystemaRev)
    HKU\S-1-5-21-3872729047-4223950186-2412060388-1001\...\Run: [ALLUpdate] => C:\Program Files (x86)\ALLPlayer\ALLUpdate.exe [3884720 2017-10-04] (ALLPlayer.org)
    HKU\S-1-5-21-3872729047-4223950186-2412060388-1001\...\Run: [Napisy24Update] => C:\Program Files (x86)\Napisy24\Napisy24Update.exe [3990528 2017-10-04] (Napisy24.pl)
    HKU\S-1-5-21-3872729047-4223950186-2412060388-1001\...\Run: [ALLPlayer WiFi Remote] => C:\Program Files (x86)\ALLPlayer Remote\ALLPlayerRemoteControl.exe [6168768 2016-09-15] (ALLPlayer Group Ltd.)
    HKU\S-1-5-21-3872729047-4223950186-2412060388-1001\...\MountPoints2: {5d0a8908-55d7-11e7-af27-1c3947d4a9a6} - "F:\autorun.exe"
    HKU\S-1-5-18\...\Run: [] => [X]
    FF user.js: detected! => C:\Users\Damian\AppData\Roaming\Mozilla\Firefox\Profiles\472p7bwi.default\user.js [2017-06-30]
    S3 update64; C:\Program Files\SystemaRev\RevServicesX\updaterev.exe [594432 2018-05-14] (SystemaRev) [Brak podpisu cyfrowego]
    R5 hagalkcj;
  • #3 17221741
    Wladyslaw666
    Now Windows defender showed me the threats:
    2 x Trojan: Win32 / Emelent.B! Cl file: C: \ Windows \ winime.exe
    3 x PWS: Win32 / Fareit file: C: \ Windows \ winime.exe
    Trojan: Win32 / Azden.B! Cl file: C: \ TDSSKiller_Quarantine \ 15.05.2018_13.29.51 \ susp0001 \ svc0000 \ tsk0000.dta
    Dr.Web CureIt! detected nothing.
    Logs below.
    • TDSSKiller.2.8.16.0_15.05.2018_13.29.50_log.txt (745.28 KB) You must be logged in to download this attachment.
    • Addition.txt (79.97 KB) You must be logged in to download this attachment.
    • Fixlog.txt (9.23 KB) You must be logged in to download this attachment.
  • #4 17221817
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    New frst.txt is missing!
  • #5 17221822
    Wladyslaw666
    My bug is already adding.
    • FRST.txt (92.29 KB) You must be logged in to download this attachment.
  • #6 17221840
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Pod Windows raczej nie usuniesz tych rootkitow.
    Uruchom Frst pod WinRe: https://www.fixitpc.pl/topic/4414-diagnostyka-infekcji-na-niestartuj%C4%85cych-windows/
    Wykonaj Fixlist.txt:
    AlternateDataStreams: C:\WINDOWS\system32\Drivers\aljlbvyr.sys:changelist [260]
    AlternateDataStreams: C:\ProgramData\Reprise:wupeogjxlctlfudivq`qsp`29hfm [0]
    HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Ograniczenia
  • #7 17221953
    Wladyslaw666
    I made a fixlist from Windows and WinRe logs in the attachment.
    • Fixlog.txt (18.69 KB) You must be logged in to download this attachment.
    • Addition.txt (69.03 KB) You must be logged in to download this attachment.
    • FRST.txt (80.17 KB) You must be logged in to download this attachment.
    • FRST(WinRe).txt (69.73 KB) You must be logged in to download this attachment.
    • TDSSKiller.2.8.16.0_15.05.2018_15.47.32_log.txt (148.65 KB) You must be logged in to download this attachment.
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Fixlist.txt last for FRST:
    Task: {0CCCF149-76AB-4A27-A7D5-140D0E810E00} - \ CreateExplorerShellUnelevatedTask -> File missing File missing
  • #9 17224528
    Wladyslaw666
    Everything works. Thanks a lot for your help :please:
The discussion revolves around persistent Trojan infections on a Windows 10 system, specifically identifying threats such as Trojan.Eps.38782, Win32/Fuerboos.C!cl, Win32/Occamy.C, and others. Users report inconsistent detection results from various antivirus programs, including Dr.Web CureIt! and Malwarebytes, with Windows Defender also flagging multiple threats. The issue is compounded by system instability, leading to unexpected restarts during scans. Recommendations include creating a system restore point, uninstalling suspicious software (e.g., NarutoOnline), and utilizing FRST (Farbar Recovery Scan Tool) in Windows Recovery Environment (WinRe) to execute a fixlist for malware removal. The user ultimately reports successful resolution of the issues after following the provided guidance.
