Internet offer 300 Mbps and the speed stays at 150 Mbps, cable fault?
Bromczak 8412 9
Why does my 300 Mbps internet connection only reach about 150 Mbps on download, and is the cable or network card limiting it?
The download limit was not caused by the cable; the ISP later found a wrong modem configuration, and after the technician corrected it the speed increased [#17227376] The short cable supplied with the modem should not affect speed, and there are no special Ethernet cables that only support 150 Mbps in the way you mean [#17226469][#17226485] Your network card is gigabit-capable, so it should support the connection speed [#17226506] If you consistently see only about 140–150 Mbps on a 300 Mbps plan, contact the provider and have them check the modem and line configuration [#17227376]
  • #1 17226411
    Bromczak
    Hello, I have an internet offer up to 300 Mbps.
    The guy who assumed it was even over 300 Mbps, but let it be. Upload is on offer at 30 Mbps, and on the speed test it is 35.
    And now the question is why the download stays at 150 Mbps? My network card is Gigabit Ethernet, so it should be okay.
    It is possible that the cable is at fault and supports up to 150 Mbps? It looks like some element limits the speed to 150 Mbps. [/ Code]
    genuine486
    Help: 20
    Rate: 59
    Wait a minute, you signed a contract for 300mbps, did the installer tell you that?
  • #3 17226447
    Bromczak
    I signed a contract for 300 Mbps, where the contract says that the minimum speed is 50% 300mbps, which is 150.
    When the fitter was at home, he said that the internet is over 300, but let it be.
    The contract says that the average should be 75% of 300 mbps.
    At this point, I have 140-150 mbps.
    I use the cable that comes with the modem, and the NIC is rather Gigabit Ethernet. All I can think of is a speed limiter or call the supplier tomorrow.
    genuine486
    Help: 20
    Rate: 59
    Do a test on speedtest.net and upload a screen shot. The cable you got with the modem is probably 1.5-3m, so it has no effect on speed.
    genuine486
    Help: 20
    Rate: 59
    No. It's the same as HDMI - cable is always the same but devices and standards change. If you are concerned about the connection speed, please contact your service provider.
  • #7 17226502
    Bromczak
    I understand. Is it possible that the built-in integrated network card does not support this speed? I checked in device manager and chose 1 Gbps, but maybe it was something else.
    Anyway, tomorrow I'll call the operator and we'll see what's up.
    Thanks for the help.
  • #8 17226506
    genuine486
    Help: 20
    Rate: 59
    The card supports it, because as you wrote above it is gigabit.
  • #9 17227319
    KOCUREK1970
    Help: 3860
    Rate: 5488
    All this is in accordance with the contract.
The discussion revolves around a user experiencing slower-than-expected internet speeds, with a contract for up to 300 Mbps but consistently achieving only 150 Mbps for downloads. The user confirmed that their network card is Gigabit Ethernet and questioned whether the issue could be due to the Ethernet cable or modem configuration. Responses suggested that the cable length was unlikely to be a factor, but the user was advised to check the modem settings. Ultimately, after contacting the ISP, it was revealed that the problem stemmed from incorrect modem configuration, which was resolved, resulting in improved speeds.
