samsung ue55nu7472 or philips 55pus7303 / 12 what should you choose?
kb1000 3405 12
Which TV should I choose for movies, sports, console games, and internet use: Samsung UE55NU7472 or Philips 55PUS7303/12?
Both TVs are similar technically, so the choice comes down to small differences and features rather than a big quality gap [#17600527][#17600793] Both use VA panels, so you get good blacks and high contrast, but both are 60 Hz models, so motion performance will not be exceptional [#17600527] The thread slightly favors Samsung because of better picture smoothing and a minimal overall advantage in picture quality [#17600527][#17600793] Philips’ main strengths are Ambilight, Android smart TV, and, according to one reply, better quality/apps/multimedia/equipment/service [#17600527][#17603737] If your budget can stretch, one user also suggested Samsung 55NU80xx as a clearly better 120 Hz option, but it is above the stated price range [#17600683]
  • #1 17600337
    kb1000
    i want to buy tv i wonder between samsung ue55nu7472 and philips 55pus7303 / 12 anyone has knowledge of these tv
  • #2 17600410
    Ludwik XVI
    Help: 1325
    Rate: 788
    I have knowledge.
    Which part do you need?
  • #3 17600447
    kb1000
    Hello! I mean image quality, sound and other things that are better to choose for watching movies, matches or games on the console
    and also about the internet
  • #4 17600478
    Ludwik XVI
    Help: 1325
    Rate: 788
    Complete and paste the survey from my signature.
  • #5 17600482
    kb1000
    unless someone has other types in this class and price range
    Added after 12 [minutes]:
    Answer the following questions to profile your needs regarding the TV you are looking for:
    1. How far are you sitting from the TV screen? 3 meters
    2. Are you sitting in front of the screen or sideways to the screen? straight
    3. What TV do you currently have? samsung40 inches
    4. What brand do you prefer? lack
    5. What size TV are you looking for? 55-60
    6. What signal and devices will be connected to the TV? cable tv decoder, ps4
    7. What kind of programs do you watch most often? sport, movies, series
    8. Will you play games, and if so on a console or a PC? yes, ps4
    9. Will you actively use the TV's SMART system? Yes
    10. You watch in the evenings or during the day? In the evenings
    11. How much money can you spend on buying a TV? up to PLN 3,000
  • #6 17600527
    Ludwik XVI
    Help: 1325
    Rate: 788
    Both models work well with you.
    Both are on VA, which means good black and high contrast.
    Smart TV differ: Samsung Tizen and Philips Android.
    Philps has Ambilight
    I would bet on Samsung because of the better picture liquefier although both tv is 60 Hz so miracles in this aspect can not be expected ...
  • #7 17600537
    kb1000
    maybe you have another option now I have a 6 year old tv but 200 Hz
  • #8 17600561
    destructor_0
    Help: 18
    Rate: 52
    now I have 6 years old tv but 200 Hz
    Can you provide the model?
  • #9 17600611
    kb1000
    ue40eh6030 writes a clear motion rate of 200 Hz I don't know if this is the case
    Added after 13 [minutes]:
    I do not know electronics so please help
  • #10 17600683
    Ludwik XVI
    Help: 1325
    Rate: 788
    The cheapest, good tv with a 120Hz matrix of 2018 is Samsung 55NU80xx.
    It's just that a few hundred above your budget ...
    The qualitative leap is then considerable in relation to the models you choose.
    You won't buy LG for 3k PLN on a VA matrix. Sony is also beyond the price range. Panasonic 2018 models only on IPS and also expensive.
  • #11 17600721
    kb1000
    and say between those I chose is the big difference in quality or not
    Ludwik XVI
    Help: 1325
    Rate: 788
    The word quality contains so many components that this question cannot be answered precisely.
    Generally, they are TV sets with similar technique used. In my opinion, Samsung has a minimal advantage.
  • #13 17603737
The discussion revolves around choosing between the Samsung UE55NU7472 and the Philips 55PUS7303/12 televisions. Key considerations include image quality, sound, and internet capabilities for watching movies, sports, and gaming on a console. Both models utilize VA panels, offering good black levels and contrast, but differ in their Smart TV platforms—Samsung uses Tizen while Philips employs Android. The Samsung model is noted for better picture processing, although both are limited to 60 Hz refresh rates. A suggestion for a higher quality option is the Samsung 55NU80xx, which features a 120 Hz matrix but exceeds the budget of PLN 3,000. Overall, opinions vary, with some favoring Samsung for its picture quality, while others highlight Philips for its superior apps and multimedia capabilities.
TL;DR: Choosing between Samsung UE55NU7472 and Philips 55PUS7303/12? Both use 60 Hz panels; "Both are on VA" with high contrast. Samsung’s motion is slightly better; Philips adds Ambilight and Android TV. Pick Samsung for smoother sports, Philips for richer apps. [Elektroda, Ludwik XVI, post #17600527]
Why it matters: This FAQ helps shoppers compare picture, motion, gaming, and smart features for movies, sports, PS4, and streaming.
Which TV is better for movies at night?
Both use VA panels, so you get deeper blacks and higher contrast in dark rooms. Philips adds Ambilight, which some viewers enjoy for perceived contrast. If your priority is pure black depth and balanced processing, both are strong picks here. Differences are modest at this level, so choose based on smart platform and features you value. "Both are on VA, which means good black and high contrast." [Elektroda, Ludwik XVI, post #17600527]
Which set is smoother for live sports and fast motion?
Both are 60 Hz, so motion handling is similar, but Samsung’s smoothing is a bit better. Enable motion settings sparingly to avoid the soap‑opera effect. "I would bet on Samsung because of the better picture liquefier ... so miracles in this aspect can not be expected." For maximum motion clarity, a 120 Hz set is the real upgrade, but it costs more. [Elektroda, Ludwik XVI, post #17600527]
Is there a big difference in overall quality between these two?
Not really. They share similar core hardware and picture traits. One expert summary from the thread: "Samsung has a minimal advantage." That tilt mainly shows in motion processing and some usability preferences, not in fundamental panel performance. If you value Android TV and Ambilight, the Philips balances that small edge. [Elektroda, Ludwik XVI, post #17600793]
Which platform is better for apps and internet streaming: Tizen or Android TV?
Both cover major streaming apps. Android TV on Philips tends to offer a broader app ecosystem and Google integrations. A contributor states: "The advantage is clear on the Philips side – Apps, multimedia, equipment, service." If you want simplicity and smooth menus, Tizen is very user‑friendly; if you want more app variety, lean Philips. [Elektroda, Anonymous, post #17603737]
Are these TVs good for PS4 gaming (input lag and features)?
Yes. Expect low input lag in Game Mode on mid‑range 60 Hz 4K TVs—typically about 20–30 ms. That’s responsive for casual and competitive console play. Use HDMI Game Mode and disable heavy motion processing for best latency. If you demand the cleanest motion in fast games, 120 Hz models help, but they cost more. [RTINGS, 2018]
Should I stretch my budget to a 120 Hz model for sports?
If sports smoothness is your top priority, yes—120 Hz is the meaningful upgrade. The 2018 Samsung 55NU80xx is the cheapest solid 120 Hz step‑up, but it’s a few hundred PLN above this budget. "The qualitative leap is then considerable in relation to the models you choose." [Elektroda, Ludwik XVI, post #17600683]
Does Ambilight make a real difference in viewing?
Ambilight projects colored bias light onto the wall behind the TV. It can enhance immersion and reduce eye strain in dim rooms. Many viewers feel it deepens perceived contrast without altering the actual panel. If you like ambient lighting or wall‑wash effects, it’s a distinctive Philips benefit. [What is Ambilight?]
My old Samsung says 200 Hz (Clear Motion Rate). Is that true 200 Hz?
No. "Clear Motion Rate 200" is a marketing metric that combines processing and backlight scanning. The native panel refresh on many older mid‑range sets was 60 Hz. Manufacturers use inflated numbers to imply smoother motion. Compare native refresh (60/120 Hz) when evaluating motion performance. [CNET, 2014]
What about viewing angles for family seating?
These VA panels look best straight on. Colors and contrast wash out as you move off‑axis, notably beyond around 25–30 degrees. If you have wide seating, consider room layout or bias lighting to help, or look at IPS/OLED for better angles. This is an edge case where VA’s strength in contrast becomes a weakness. [RTINGS, 2023]
Which has better sound out of the box?
Both are thin 55‑inch sets with modest speakers. Dialogue clarity and bass are limited by cabinet size. A compact soundbar or 2.1 system is a worthwhile upgrade for movies and sports. Modern TVs often trade speaker volume for slim design, so plan audio separately for best results. [TechRadar, 2018]
Are there alternative models in this price class worth a look?
For 120 Hz in 2018, Samsung 55NU80xx is the entry point, but it’s over budget. You won’t find VA from LG at 3,000 PLN. Sony’s comparable options sit above this price. Panasonic’s 2018 models were IPS and also expensive. Within budget, your two picks are sensible. [Elektroda, Ludwik XVI, post #17600683]
How can I decide quickly between these two? (3-step)
  1. Choose your Smart OS: Tizen (Samsung) for a simpler UI or Android TV (Philips) for broader apps.
  2. Decide if Ambilight matters to you for ambience and perceived contrast.
  3. Accept both are 60 Hz; for slightly smoother sports within these two, lean Samsung. [Elektroda, Ludwik XVI, post #17600527]
