Emmerson MR-150BT Bluetooth Speaker: Fixing H1 Error Display Issue - Tips & Solutions Needed
Sid998 12387 6
  • #1 17237661
    Sid998
    There is a problem with the Emmerson MR-150BT bluetooth speaker, specifically the display shows only the H1 itself and I can't set anything, etc., not to mention music playback, etc.
    Does anyone know a patent for it, how to fix it? Maybe it is not something difficult, and what I would like to deal with myself, I could only use hints from someone from Forum members.
    Thanks.
  • #2 17365301
    zlotowlosa
    Rate: 27
    I have the same problem. Were you able to solve it?
  • #3 17373933
    radek0008
    Rate: 27
    Hello, it may help to discharge the battery completely.
    but not necessarily
  • #4 18026252
    maxnax
    Would anyone make SPI flash dump for yhis speaker ? There's a chance to make one good dump out of two bad
  • #5 18575809
    niko.n
    For me, it helped to hold the radio mute button for a few seconds, i.e. V-
  • #6 18576163
    maxnax
    Now way. So what about dump ?
  • #7 20417162
    jurekSawicki
    Rate: 20
    I wrote to the address:
    service(_at_)emmerson.com.pl
    that I have - "message H1" on NewAudio MR-150BT -
    They sent me a link to download the service program and updates via the "We Transfer" service.
    You have to download it to your computer within three days (then the program disappears) and run this program
    (It's good to have a computer scientist on hand; I did.)
    You need a USB-USB cable - not micro-USB.
    The guys from the site will explain how to proceed with the program ...
    ... and after uploading this program, the tube worked.
    And this is the address of Emmerson himself:
    http://www.emmerson.com.pl
    Good luck, jurekSawicki@tychy(70)
    Added after 10 [minutes]:
    maxnax wrote:
    now. So what about the dump?
    We talk about repairing, not dumping. ;-)
    Look to my answer...
    Yours friend, jS@tychy
✨ The Emmerson MR-150BT Bluetooth speaker is experiencing an H1 error display issue, preventing users from accessing settings and music playback. Several users have reported similar problems and shared potential solutions. Suggestions include completely discharging the battery, holding the radio mute button (V-) for a few seconds, and contacting Emmerson's support for a service program and updates. One user successfully resolved the issue by downloading a service program via a link provided by Emmerson, requiring a USB-USB cable for the process. There is also a request for an SPI flash dump to potentially recover from the error.
