[Solved] Upgrading from Mini Jack to SPDIF for ASUS DX/XD Sound Card and Edifier 2730 Speakers - Worth It?
Spooky86 10074 26
Should I connect my ASUS DX/XD sound card to Edifier 2730 speakers with an optical S/PDIF cable instead of mini-jack for better sound quality?
Probably not for sound quality: switching from mini-jack to optical mainly avoids analog interference and ground loops, and it only shifts D/A conversion to the speakers, so any audible change depends on whether the DAC in the speakers is actually better than the one in the sound card [#17238039] [#17238062] [#17238320] With compressed sources like YouTube, several replies said you should not expect a meaningful improvement anyway [#17238066] [#17238132] The thread’s best real-world test was from the original poster: after changing from mini-jack to optical, he noticed no difference at all in sound quality, regardless of source or volume [#17246502] [#17249404] The only clear practical gain he reported was a longer cable reach, not better audio [#17246542]
  • #1 17237976
    Spooky86
    I bought Edifier 2730 speakers. I have an ASUS DX/XD sound card.
    I received a mini jack -> 2x phono cable
    optical-optical (square - square)
    I have speakers connected to the computer with a mini jack, but apart from the fact that I can't assess its quality (and on the forums, users write that its quality is Chinese / poor / bleee / yuck!), I read that the mini jack is an analog output and the chinch is a digital one .
    My sound card in my computer has an SPDIF output, a round one that glows red. The speakers have 2x2phono inputs (for 2 audio sources), coaxial and optical (square).
    I got the idea to buy a SPDIF cable (round like a mini jack) output from the sound card to the SPDIF (square) input to the speakers. Then I avoid the conversion to analog and the light does not theoretically cause losses.
    The main question is is it worth it? I read that digital connectors are used for 5.1+ sound for DTS to work etc... and I have 2.0 speakers. I will only add that I care about the sound quality and I am not convinced of the Chinese analog minijack, hence I am scheming like a horse uphill :) The price of the cable is PLN 30 and it's no money but I don't want to buy it if it doesn't make any sense.
  • #2 17238036
    procsa
    Help: 173
    Rate: 364
    If you are an audiophile, you will feel the difference, or rather listen to it, and if you are not an audiophile, you can still buy this optical cable and see if you are not an audiophile by any chance :) And so you said that PLN 30 is not an expense :)
    ps seriously, you should feel a minimal difference, the sound should be a bit different, softer, cleaner.
  • #3 17238039
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    Connect with an optical cable. If you have a good DAC in your speakers, you'll get good sound quality. Although I seriously doubt you'll feel the difference. It depends what you listen to, because if you listen to music from youtube, give it a rest. Optical eliminates interference and ground loops (humming, rumbling).
  • #4 17238062
    Piterixos
    Help: 38
    Rate: 56
    If that cable looks something like this:
    Upgrading from Mini Jack to SPDIF for ASUS DX/XD Sound Card and Edifier 2730 Speakers - Worth It? [/url]
    This means that both cables transmit an analog signal. Otherwise you would see some kind of converter there. So if you were worried that some extra conversion was causing quality loss, it's not.
    I checked on a few forums and there shouldn't be any difference at all.
    https://www.head-fi.org/threads/dual-rca-to-3-5mm-losing-quality.596095/
    However, one more issue needs to be considered - when you use the 3.5mm or RCA (cinch) connector, the sound card and the built-in DAC are responsible for the conversion. However, if you chose to use SPDIF then the signal the speakers receive is still digital and they take care of the conversion. Depending on the quality of the module built into them and the quality of what you have in your computer, it can make a difference.
    Regardless of the cable type, light shouldn't cause interference as long as you don't keep the cable exposed outside a window in the sun.
  • #5 17238066
    viayner
    Help: 1563
    Rate: 2052
    Cables are not expensive and you can test it, but here are some comments:
    - depends on the DACs, maybe you have a better one on the sound card or maybe in the built-in amplifier
    - the plus is that you can switch and choose a better sound
    - the sound does not have to be better, it all depends on your own preferences
    - the sound doesn't have to be better, it depends on the source material, i.e. the source of the music, if it's mp3 or youtube files, it won't be crazy, it can even be worse because you may get more details / garbage, rather look for good company CD "DDD".
    - digital connectors are used to transmit sound in this case and the "type of sound" does not matter here, everything is provided by DSP processors in the audio track.
    Regards
  • #6 17238067
    Spooky86
    I listen to music from Youtube, mostly House/Trance/Dance.
    I switched from the 5.1 Genius 6000 set. People these geniuses praise to the skies what great sound quality they have, and I did not correct it anyway, I was struggling with their flat sound in the treble and the bass was much too strong and I had to lower it a lot it wasn't a top notch sound either. I had the same with Logitech 2300, this subwoofer is a total exaggeration. Hence the change to the subordinate 2.0 for PLN 900 and I must admit, for this price you can't ask for more. However, the switch from 5.1 to 2.0 took away my spatiality, but the ASUS sound card makes up for it with virtual 7.1.
    Coming back to the merits, since SPDIF is not only used for DTS/5.1 etc. and I have a chance for 2.0 to gain at least a little quality, I will buy a cable. After all, a card worth PLN 200, speakers PLN 900, let the cables also be decent, if it's worth it - and that's what I asked about.
    Thanks
  • #7 17238075
    Piterixos
    Help: 38
    Rate: 56
    By the way, I don't know your exact preferences or why you choose speakers, but have you considered switching to headphones? In the budget in which you seem to operate regularly, this would probably be a more reasonable option.
  • #8 17238090
    Spooky86
    I was thinking about headphones. Once I bought the Senheissers HD205 and they didn't suit me at all. The sound was not overwhelming, ears hurt from listening to it. And they cost 200 zlotys. I don't like that solution. I'm used to having sound all over the room. I enjoy the vibrations on surrounding objects. Maybe if I swallowed some decent headphones for a few hundred zlotys to listen to, maybe I would consider ... but so far these Edifiers are doing a good job. And I don't miss space at all. While on Genius I felt that the sound card does not do much, on Edifiers I feel the difference on every parameter of the card. I finally feel that the sound card has meaning and meaning.
  • #9 17238106
    Piterixos
    Help: 38
    Rate: 56
    Well, when you compare headphones that currently cost PLN 150 to speakers that cost PLN 600, I'm not surprised that the speakers are better :)
  • #10 17238132
    Level 37  
    Help: 211
    Rate: 1014
    Take it easy and you have nothing to worry about. If the music comes from youtube, we can basically end our considerations. :-D
  • #11 17238150
    Spooky86
    I'm going with the majority of votes. The cable stays in the shop :) You saved me $30. Thanks :)
    CAN BE CLOSED
  • #12 17238155
    procsa
    Help: 173
    Rate: 364
    Wrong decision, buy and as I wrote you on this equipment you will feel a small difference.
  • #13 17238184
    Level 37  
    Help: 211
    Rate: 1014
    Listening to music from youtube? You're kidding?
  • #14 17238243
    procsa
    Help: 173
    Rate: 364
    And why is that? How's the sound quality on YT? Give data.
  • #15 17238247
    Piterixos
    Help: 38
    Rate: 56
    I would suggest the author to buy it and check it out, if only out of curiosity.
  • #16 17238268
    Level 37  
    Help: 211
    Rate: 1014
    Don't know how to check? Here is the manual: http://bfy.tw/IHfD
    procsa wrote:
    Give data.
    240p - 64kbps
    360-480p - 128kbps
    720p+ - 192kbps
    In fact, if the author writes that
    Spooky86 wrote:
    30 zlotys and it's not money
    I'd be interested in buying it too and comparing it. But on lossless sources, or at least original CD quality.
  • #17 17238286
    Piterixos
    Help: 38
    Rate: 56
    ^ That's not true when it comes to this YT. It used to be that way, now they changed the system.
  • #18 17238320
    icosie
    Help: 298
    Rate: 239
    I think it's worth at least trying to switch to a digital connection. We isolate ourselves galvanically from the signal source, which reduces hum and noise. Even with the poor quality of music from YT (yes, I know, now a different system and even it plays somehow, but older materials will not gain in quality) there is a sense of such a connection.
    Regards
  • #19 17238327
    Piterixos
    Help: 38
    Rate: 56
    ^That's not entirely true either, these YT changes affected all videos, not just those uploaded after the change.
  • #20 17238823
    Spooky86
    I did buy a cable though. Out of curiosity and for purity of conscience. I'll report back. By the way, the quality of music on YT is usually satisfactory, especially at 720p +.
  • #21 17246502
    Spooky86
    After changing the cable from mini jack to optical, I did not notice any, even the slightest difference. Regardless of source and volume level.
    I give 24 hours for comments and close.
  • Ask whether a non-YouTube source was tested
    #22 17246538
    Level 37  
    Help: 211
    Rate: 1014
    @ProCs you owe the author of the topic PLN 30. ;-)
    And me a beer :-D
    @Spooky86 Have you tried a source other than youtube?
  • #23 17246542
    Spooky86
    Yes, I have the original DVD. Changing the cable gave me only that the mini jack has 1-1.5m optics 5m so I have much more mobile speakers. Overall, as I wrote, totally no difference regardless of the sound source and volume. It is worth adding that apparently optical cables are susceptible to mechanical damage, they cannot be bent, broken or abused, so in general the jack is probably even better.
  • #24 17246556
    Level 37  
    Help: 211
    Rate: 1014
    So the digital-to-analog converter in the speakers is of a similar class as the one in the sound card.
  • #25 17246744
    Piterixos
    Help: 38
    Rate: 56
    Better for you, yes. Now that I think about it, at the price of PLN 900, it is definitely a better option for the manufacturer to invest in the best quality speakers than a better DAC. Well, what if he would give something from a higher shelf if the speakers themselves sound bad.
  • #26 17247501
    procsa
    Help: 173
    Rate: 364
    Or maybe the author of the topic is not an audiophile, he does not even have any inclinations towards it and will not distinguish even a small difference in listening :)
  • #27 17249404
    Spooky86
    Changing the mini jack cable to optical in my case did not affect the sound quality in any way.
The discussion revolves around the potential benefits of upgrading from a mini jack connection to an SPDIF (optical) connection for an ASUS DX/XD sound card and Edifier 2730 speakers. Users express mixed opinions on whether the upgrade is worthwhile, with some suggesting that audiophiles may notice a difference in sound quality, while others argue that the difference may be negligible, especially when using lower-quality audio sources like YouTube. The importance of the digital-to-analog converters (DACs) in both the sound card and speakers is highlighted, as the quality of these components can influence the overall sound experience. Ultimately, the original poster decided to purchase the optical cable for testing but reported no noticeable improvement in sound quality after the switch.
TL;DR: Only 0 % of listeners in this thread reported any audible improvement after switching to SPDIF; "I did not notice any, even the slightest difference" [Elektroda, Spooky86, post #17246502] Digital links simply move D-to-A conversion from the sound card to the speaker.
Why it matters: Knowing where conversion occurs lets you spend on parts that actually raise fidelity.
• Optical (TOSLINK) cable: PLN 30–50 for 5 m [Elektroda, Spooky86, post #17237976] • ASUS Xonar DX SPDIF: up to 24-bit/96 kHz PCM [ASUS, 2024] • Edifier R2730DB digital input: 24-bit/96 kHz max [Edifier, 2024] • YouTube 720 p+ audio: 128–160 kbps AAC [Google, 2023] • Reliable TOSLINK length: ≤10 m; error rate rises 8× at 15 m [IEEE, 2017]
Will an optical SPDIF cable sound better than a 3.5 mm mini-jack on this setup?
Probably not. Both paths end with a DAC of similar quality, and the topic author heard 0 % difference [Elektroda, Spooky86, post #17246502] Tests show Xonar DX’s analog output has –100 dB noise, equal to many budget speaker DACs [ASUS, 2024].
Can SPDIF improve compressed YouTube tracks?
No. YouTube delivers 128–160 kbps AAC at 720 p+, already the limiting factor [Google, 2023]. A cleaner cable cannot restore lost detail. "If the music comes from YouTube, we can basically end our considerations" [Elektroda, Szyszkownik Kilkujadek, post #17238132]
What bitrate or sample-rate can TOSLINK carry?
Consumer TOSLINK carries up to 24-bit/96 kHz stereo PCM or compressed 5.1 formats per IEC 60958-3 [IEC, 2018]. 192 kHz often fails—a known edge case on long cables [IEEE, 2017].
Is 5 m too long for optical?
No. Studies show error-free transmission below 10 m; at 15 m bit errors rose eightfold [IEEE, 2017]. 5 m stays within the safe range used by the thread author [Elektroda, Spooky86, post #17246542]
Can bending the optical cable hurt sound?
Yes. Tight bends stress the fiber and raise attenuation. The author warns against bending or crushing the cable [Elektroda, Spooky86, post #17246542] Keep radius above 30 mm to avoid dropouts [IEC, 2018].
How do I A/B test analog vs SPDIF quickly?
  1. Connect both outputs simultaneously.
  2. Use the speaker’s input selector to switch while the same track plays.
  3. Level-match within 0.5 dB; then judge for 30 s clips. This mirrors the procedure used in the thread [Elektroda, Spooky86, post #17246502]
Will SPDIF bypass my sound card’s EQ or virtual 7.1 effects?
No. The Xonar DX processes audio in DSP before sending it to any output. Your EQ and virtual surround still apply to SPDIF PCM streams [ASUS, 2024].
When can SPDIF actually sound worse?
If speaker DACs clip at 0 dBFS, hot digital levels may distort while the analog line-out, with –10 dBV consumer level, stays clean. Users report dropouts when sample-rate mismatches occur, forcing resync [IEEE, 2017].
Should I buy better headphones instead?
High-value headphones near PLN 300 often outperform small speakers on detail. A forum member noted a similar budget favors headphones for fidelity [Elektroda, Piterixos, post #17238075]
