[Solved] VW Passat B6 2.0 FSI - Error P0016: Idle Misfire, Timing Replacement & Phase Valve Fault
spinacz 16521 4
  • #1 17242309
    spinacz
    Help: 1204
    Rate: 2654
    Colleagues suddenly my Passat is idle as if it had a misfiring. The first thought of the coil, however, was a mistake as in the subject.
    Is it the fault of the variable phase valve itself on the shaft or is the timing replacement waiting along with the complete chain linking the fight?
    The fact that it's time to replace the timing gear.
    ASO wants PLN 3,000 for this service with the material.
    Is there anything else for this error? [/at]
  • #2 17242313
    fructon
    Help: 241
    Rate: 982
    In most cases, however, it is a stretched chain.
  • #3 17242328
    spinacz
    Help: 1204
    Rate: 2654
    And if it's not a chain, what could it be?
  • #4 17262334
    spinacz
    Help: 1204
    Rate: 2654
    Colleagues, the chain tensioner, everything is perfect, the valve of the variable valve timing turned out to be damaged. The fault was found after 10 hours of ASO fight, the cost of the valve with replacement PLN 600.
  • #5 17265503
    spinacz
    Help: 1204
    Rate: 2654
    Solution as above.
