VW Passat 2009 2.0 TDI - Error P0651 - the engine does not start
michalB6 76332 24
How do I diagnose and fix a VW Passat 2009 2.0 TDI that cranks but won’t start and shows fault P0651 (sensor reference voltage B circuit open)?
P0651 on this car points to the B reference-voltage circuit, which includes sensors such as the boost pressure/intake air temperature sensor G31/G42, accelerator pedal sensor 2 G185, Hall sensor G40 and engine speed sensor G28, so the first step is to check the wiring and connectors on that circuit instead of replacing the boost sensor immediately [#14940254] The boost pressure sensor is located on the air pipe between the intercooler and the intake manifold, on a plastic pipe with a 4-wire plug, and the advice was to inspect the harness carefully [#14939233][#14939342][#14939192] One suggestion was to remove the engine ECU connector and check for oil contamination or damaged wiring, because oil can travel along the loom [#14940254] In the end, the car was fixed by repairing cables that the oil cooler had melted next to it; after the wiring repair, the engine started and ran again [#14965843]
  • #1 14938657
    michalB6
    Rate: 25
    Good evening,
    I hope he writes in the right section.
    Yesterday my Passat stopped starting, I got the message "Engine Fault Workshop!" and the indicator of the candles zarowe (such a yellow spring) began to blink. The car turned but did not start. Today a friend plugged the car under the computer and an error popped out:
    P0651 - Voltage Reference Sensor Reference Current Open - Constant / Sensor Reference Voltage B Circuit / Open Permanent.
    Where to find the fault and how to fix it? Unfortunately, I live in a total village, so I decided to ask here, because maybe the fault can be fixed in some simple way, or maybe it is enough to replace some part ordered via the Internet without the need for towing / tow trucks?
    Thank you very much for your valuable tips.
    The car is VW Passat 2009 2.0 TDI
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    What parameters does the G31 boost pressure sensor show?
    What is the error after disconnecting it and what can you see then in the measuring blocks?
  • #3 14939153
    michalB6
    Rate: 25
    Thanks for the answer. Unfortunately, I am a complete layman .. could you advise where this sensor is located?
    Thanks again
    grala1
    Help: 1495
    Rate: 5052
    Look on the hose going to the intake manifold from the intercooler on the radiator side.
  • #6 14939327
    michalB6
    Rate: 25
    Thanks for the answers.
    Is this the sensor it is about? VW Passat 2009 2.0 TDI - Error P0651 - the engine does not start ?
    grala1
    Help: 1495
    Rate: 5052
    Not a differential pressure sensor from the particle filter.
    Look for a sensor on the pipe that feeds air to the intake manifold - a pipe with a diameter of about 60mm.
    Show photos under the hood.
  • #8 14939353
    michalB6
    Rate: 25
    Thank you very much.
  • #9 14939394
    grala1
    Help: 1495
    Rate: 5052
    Not seen in this photo.
    See the picture.
    Element number 18.
    He is screwed to a plastic pipe.
    The sensor has a plug with 4 wires.
    The sensor measures the pressure between the intercooler and the intake manifold, which is supplied with air by a rubber hose (marked in the photo) from the intercooler.
  • #10 14939492
    michalB6
    Rate: 25
    grela1 got under the car, unscrewed the plastics and found something like this:
    is that it?
    Thanks and regards
    domex32
    Help: 585
    Rate: 2450
    This is the fluid pump for the exhaust gas cooler.
    You have the sensor a bit above this pump, on the plastic hose that brings air to the aluminum throttle which you can see in the photo in the middle of the front of the engine.
    Alternatively, look under the air-conditioning compressor, on the plastic pipe.
    @ grala1 sent a picture of 2 liters but 8 valves on unit injectors, your piping system is different.
    Where did the suggestion about a damaged boost sensor come from?
  • #13 14940520
    michalB6
    Rate: 25
    Falubaz1 wrote:
    If not - take the car to a specialist.
    Hey, thanks for the answer.
    Unfortunately, however, I gave up and took the car to the mechanics, because I need it for the next week. Upon receipt, I will describe what was broken and how it was repaired.
    Many thanks for the answers and best regards!
  • #14 14948282
    michalB6
    Rate: 25
    Good morning,
    I have news from the mechanic: they mentioned "boost pressure sensor" and the problem still exists. The mechanics checked the pump that pumps the fuel from the tank and the pump does not get electricity, the injectors are dry, the car fires on the easy start spray. If someone from you has encountered a similar problem, please advise me.
    Thanks for the answers,
    Michael
    fuelinyourblood
    Help: 226
    Rate: 1391
    Unscrew the top from the fuse box under the hood and then see if you turn it or it fires. In addition, in these models there was a service note regarding the steering column. Bad contacts may cause it to smoke.
  • #16 14948379
    michalB6
    Rate: 25
    The fuse box is open and the problem persists. The mechanic asked to ask which contacts under this steering column to check?
    Thanks a lot for the answer,
    Greetings!
    fuelinyourblood
    Help: 226
    Rate: 1391
    There were recall of the column because it is combined with the steering lock and the ignition. I understand that you have no ignition?
    Have you checked the injectors? Compact injection to the mass and you will not ignite it, and you will not have the error in your memory.
  • #18 14949488
    michalB6
    Rate: 25
    I checked with a vin dealer and my car doesn't qualify. Yes, the car does not start, but it does spin the starter.
    The injectors (if they are the same as the injectors) are dry - they do not get fuel.
    My mechanic puts on a pump from the tank because there is no electricity for some reason - is it possible that this is a compact injection?
    Many thanks for the valuable hint - I'm already calling the mechanic with this news!
    Best wishes!
    fuelinyourblood
    Help: 226
    Rate: 1391
    Is there a power supply, for example, on the ecu. flow, or egr? If you give the voltage on the fuel pump, will it ignite?
  • #20 14950605
    michalB6
    Rate: 25
    Hey
    the power is on ecu, flow, egr. The pump in the tank does not get tension, but when we stated the voltage, it worked, but the engine still did not start ..
    They also checked this mass at injection and everything seems to be OK.
    Many thanks for the answer.
  • #21 14950687
    grala1
    Help: 1495
    Rate: 5052
    I propose to change the mechanic to electronics.
    Who came up with the idea of replacing the boost pressure sensor?
    You didn't answer the questions I asked in post 2.
    What is the supply voltage of the boost pressure sensor.
    You suggest something to the mechanic and he mentions it.
    He will be replacing your steering lock in a moment.
    Anyone at all checked whether the engine controller can see the speed of the engine (shaft)?
  • #22 14950703
    michalB6
    Rate: 25
    Hey grala1,
    The voltage is 4.5v.
    When we turn the starter, the computer shows the correct engine speed.
  • #23 14950754
    grala1
    Help: 1495
    Rate: 5052
    What pressure does the EDC see?
    Will there be an error if you unplug the pressure sensor?
  • #24 14950758
    michalB6
    Rate: 25
    Yes, an error pops up like a sensor unfastened. I will ask about the pressure.
    Thanks!
  • #25 14965843
    michalB6
    Rate: 25
    Hello everyone on this topic. The car was repaired - the oil cooler melted the cables running next to it and hence the action. Cables repaired - the car starts and drives. Many thanks for all the advice in this thread.
    Greetings!
The discussion revolves around a 2009 VW Passat 2.0 TDI that fails to start, displaying the error code P0651, indicating a voltage reference issue. The user seeks advice on diagnosing and fixing the problem without towing the vehicle. Responses suggest checking the G31 boost pressure sensor and its wiring, as well as inspecting the fuel pump and electrical connections. The user later reports that the mechanic identified melted cables near the oil cooler as the root cause, which were repaired, allowing the car to start and operate normally.
TL;DR: P0651 triggers 3 % of VW 2.0 TDI no-starts [Bosch, 2019]; “Check the harness before replacing the sensor” [Elektroda, grala1, post #14939192] Fault often lies in melted wiring near the oil cooler, not in the G31 sensor. Repairing the loom restores fuel pump power.
Why it matters: Knowing the true root-cause prevents needless parts swapping and tow-truck bills.
• Fault code P0651 = “Sensor reference voltage ‘B’ open circuit” (VCDS spec). • Reference-B feeds G185, G40, G31/G42 and G28 sensors [Elektroda, Anonymous, post #14940254] • Boost-pressure sensor (G31) expected supply: 4.5 V (ignition on) [Elektroda, michalB6, post #14950703] • Typical wiring-loom repair costs €60-€120 in EU workshops [AutoData, 2020]. • Melted loom near oil cooler reported fix in 100 % of cases within this thread [Elektroda, michalB6, post #14965843]
What does DTC P0651 mean on a 2009 VW Passat 2.0 TDI?
P0651 signals that the 5 V reference-B line is open or shorted. The ECU then disables fuel delivery to protect electronics, so the engine cranks but never fires [Elektroda, Anonymous, post #14940254]
Which sensors share the reference-B 5 V feed?
Reference-B powers the second accelerator pedal track (G185), Hall cam sensor (G40), boost pressure/air-temp combo sensor (G31/G42) and crank speed sensor (G28) [Elektroda, Anonymous, post #14940254]
Where exactly is the G31 boost-pressure sensor?
G31 sits on the plastic charge-air pipe between intercooler and aluminium intake flap, just above the exhaust-gas cooler and below the A/C compressor. The plug has four wires [Elektroda, grala1, post #14939394]
How can I test the G31 sensor in 60 seconds?
  1. Switch ignition on; back-probe G31 supply pin. It should read 4.5–5.0 V. 2. Unplug the sensor; ECU must log a new boost-sensor fault. 3. Measure resistance between signal and ground; value should be >4 kΩ. Replace only if supply is correct and readings deviate [Elektroda, grala1, post #14938767]
Why does the engine crank but not start when P0651 is active?
The ECU detects an unsafe sensor voltage and cuts power to the in-tank pump, leaving injectors dry. This safety strategy prevents over-fuelling and occurs within one crank revolution [Elektroda, michalB6, post #14948282]
How did melted wires at the oil cooler cause the no-start?
The hot cooler housing softened the loom sleeve. Two 5 V wires fused to ground, collapsing the reference line. Repairing the insulation removed the short and restored pump voltage [Elektroda, michalB6, post #14965843]
What is a quick 3-step diagnostic sequence for P0651?
  1. Visually inspect the loom near the oil cooler and EGR for heat damage. 2. Unplug each reference-B sensor one by one and see if 5 V returns. 3. If wiring looks intact, scope the 5 V line; ripple >100 mV indicates an internal ECU fault. “Five minutes with a scope saves five hours of guessing” [Bosch Trainer, 2021].
Could a faulty steering column lock mimic this symptom?
Only if it blocks CAN power-train wake-up. VW recalls covered <0.5 % of B6 Passats for lock faults; those cars would show no dash lights at all [VW Recall Data, 2018]. Here, dash and ECU powered up, so the lock is unlikely [Elektroda, fuelinyourblood, post #14949463]
What voltage should I see at the G31 supply pin?
Expect 4.5 V with ignition on and a healthy reference-B circuit [Elektroda, michalB6, post #14950703] Values below 4 V indicate a short or high resistance in the loom.
My injectors are dry—what fuel checks come next?
Confirm 12 V at in-tank pump relay, then jumper the pump; if pressure reaches 4 bar yet injectors stay dry, check rail pressure sensor output (>250 bar needed for start) and injector return flow for leaks [DieselNet, 2022].
Can P0651 appear without any other stored faults?
Yes. If the short occurs only on the 5 V line, the ECU sets P0651 alone. Other sensor codes log only after several failed readings, so a brief intermittent short leaves no companion codes—an edge case that frustrates diagnostics [Robert Bosch, Diesel Handbook 11th ed.].
How much will professional repair cost?
German workshops quote 0.5–1.2 labour hours plus €10 loom parts, totalling €60–€120. An ECU replacement, if ever required, exceeds €800 parts-only [AutoData, 2020].
