Passat B6 2.0 FSI: Multi-Cylinder Ignition Loss, Coil Swap, Error Codes & Flap Position Sensor
bula17 12303 4
  • #1 16361482
    bula17
    Help: 52
    Rate: 295
    Hello topic quite a strange guy came from Check errors as below I deleted the errors I fired had a large ignition loss on the 4th cylinder I exchanged coils with the 3rd cylinder and calm is again falling out of the 1 Cylinder and a very large ignition loss count after a while random falling out on subsequent cylinders.
    Anyone had a similar case ??
    At times, the ignition does not count, and everything is ok
    Address 01: Engine Label file: 06J-906-026-CAW.clb
    Item designation: 06J 906 026 D HW: 06J 906 026 D
    Component and / or version: MED17.5 2424
    Coding: 0404000318070160
    Service code: WSC 00028 028 00001
    VCID: 2B55F6608AF96D1A44-807E
    5 - number of errors found. Here they are:
    008213 - Flap position sensor in the intake manifold (assembly 1)
    P2015 - 000 - incomprehensible signal - MIL on
    Frozen frame:
    Error status: 11100000
    Error priority: 0
    Error rate: 254
    Internal error counter: 255
    Mileage: 154713 km
    Time indicator: 0
    Date: 2017.01.13
    Time: 12:03:14
    Frozen frame:
    Engine speed: 1685 / min
    Load: 45.9%
    Speed: 0.0 km / h
    Temperature: 60.0 * C
    Temperature: 5.0 * C
    Pressure: 970.0 mbar
    Voltage: 14.351 V
    P2015 - 000 - incomprehensible signal - Occasional
    Frozen frame:
    Error status: 00100000
    Error priority: 0
    Error rate: 254
    Mileage: 154722 km
    Time indicator: 0
    Date: 2017.01.13
    Time: 16:28:36
    Frozen frame:
    Engine speed: 3409 / min
    Load: 61.5%
    Speed: 49.0 km / h
    Temperature: 75.0 * C
    Temperature: 7.0 * C
    Voltage: 14.097 V
    000769 - Cylinder 1
    P0301 - 000 - Ignition loss detected - Occasional
    Frozen frame:
    Error priority: 0
    Error rate: 1
    Mileage: 155 754 km
    Time indicator: 0
    Date: 2017.03.20
    Time: 08:51:31
    Frozen frame:
    Engine speed: 927 / min
    Load: 22.0%
    Speed: 0.0 km / h
    Temperature: 27.0 * C
    Temperature: 12.0 * C
    Pressure: 980.0 mbar
    Voltage: 14.224 V
    000771 - Cylinder 3
    P0303 - 000 - Ignition loss recognized - Occasional
    Frozen frame:
    Error priority: 0
    Error rate: 1
    Mileage: 155 754 km
    Time indicator: 0
    Date: 2017.03.20
    Time: 08:51:31
    Frozen frame:
    Load: 22.0%
    Speed: 0.0 km / h
    Voltage: 14.224 V
    000772 - Cylinder 4
    P0304 - 000 - Ignition loss recognized - Occasional
    Frozen frame:
    Error priority: 0
    Error rate: 1
    Mileage: 155 754 km
    Time indicator: 0
    Date: 2017.03.20
    Time: 08:51:31
    Frozen frame:
    Load: 22.0%
    Speed: 0.0 km / h
    Voltage: 14.224 V
  • #2 16363329
    r_Lunar
    Rate: 32
    you probably need to regenerate or replace the air intake flaps.
    Ignition loss may also, although rarely, indicate the formation of cracks in the engine block
  • #3 16363346
    bula17
    Help: 52
    Rate: 295
    I found the reason, it turned out that when the flaps go, when controlling the flaps there is damage and pulls the left air and the flaps in the middle stand in one position I go for a collector 1430 PLN ASO and it must be ok :)
  • #4 16363358
    r_Lunar
    Rate: 32
    you don't have to buy a collector for 1430 PLN
  • #5 16365348
    bula17
    Help: 52
    Rate: 295
    Subject completed collector changed to new and everything is ok. For me, there was a constant left air when controlling the flaps, it was not heard until after placing my finger, I could feel my finger being drawn.
