Hotpoint-Ariston LST 328 A HA Dishwasher - Error 6 Issue, Pumping Water & Blinking Key
Snp123 11910 5
  • #1 17243507
    Snp123
    Rate: 12
    After switching on, everything seems fine - it is pumping water correctly into the system. After a while, you can hear a micro-switch switching several times. The dishwasher then turns off and begins to beep and then pops up error No. 6 plus the blinking key from turning on the machine. Does anyone have an alarm list or associate this error number?
    I will be grateful for any help
  • #2 17243695
    MARiTv
    Help: 10
    Rate: 13
    In a different model
    F06 - Drain pump error or F6
    o No water in the network.
    o The water drain hose is bent
  • #3 17243737
    Snp123
    Rate: 12
    The same could be read in the manual. There is nothing else but to disassemble the system and see what and how.
    Question, do I understand that error 6 is the same indication as, for example, F06 in other models?
  • #4 17243777
    MARiTv
    Help: 10
    Rate: 13
    It's hard to feel, but I noticed if the number of error codes in Ariston hardware is less than 9, F1 to F9 are displayed.
    And two digits display F01, F10 etc.
  • #5 17243796
    Snp123
    Rate: 12
    I will try to embrace the subject and of course write what was. Just try to get to know what is what hehe. Finally my 1 time with this equipment :-P
  • #6 17246113
    Snp123
    Rate: 12
    At the moment, it turned out that no water is being drawn into the dishwasher (I misjudged at the beginning).
    - I measured the voltage supplied to the solenoid valve coil located on the hose supplying the dishwasher with water.
    At the time of theoretical water withdrawal - 230 volts - also correct
    - I am not able to check the patency of the water supply cable due to the construction of the housing (photo attached)
    I have the impression that it forms one whole and its "opening" will mean its destruction.
    1. Is there a good diagnosis faulty solenoid valve , be power cable him?
    2. Is it possible to buy and possibly replace the solenoid valve itself?
    3. What if I put the water supply hose in the water for a short time, omitting all electronics.
    Would the dishwasher work properly? I think not.
    Thanks for any helpful info :)
