Hotpoint Ariston LFF8M121 CX EU - does not take water after a moment of humming
piotrd1 14316 10
Why does my Hotpoint Ariston LFF8M121 CX EU dishwasher hum for a moment, then stop taking water and show F15?
The most likely cause is a blocked or faulty drain pump, which matches the F15 code and the humming/no-fill behavior [#16184028][#16184709] If the pump is OK, check the inlet solenoid valve; one reply suggests removing it and testing it with 230 V to see whether it operates [#16204602] Another reply says a damaged heater can also produce the same symptoms, so inspect both the heater and the solenoid valve [#16208430]
  • #1 16182053
    piotrd1
    Rate: 55
    Thread rolled dishwasher Hotpoint Ariston LFF8M121 CX EU
    Nowhere did I find help error F15 when washing and the indicator light from a clogged filter came on. Filter clean restart and does not take water after a while humming and error F15
    Chupacabra
    Help: 247
    Rate: 868
    Drain pump blocked or defective.
  • #3 16184353
    piotrd1
    Rate: 55
    Well, but when I turn it on, it first pumps out water and begins to buzz. Interestingly, I turned it on and pumped it up, buzzed and took water after the turn. He went through the whole program so I loaded it with more dishes and the fun ended. Pumped, buzzed several times and f15.
    Chupacabra
    Help: 247
    Rate: 868
    Are you a foreigner, do you just have to write in Polish somewhere correctly? You cannot learn anything from your posts, you have to guess. I continue to bet on the ending drain pump. Upload a short video from the moment you turn it on until the error occurs.
  • #5 16184825
    piotrd1
    Rate: 55
    Sorki but he writes from the phone and he sometimes changes the words in the afternoon I will throw a movie
  • #6 16204320
    piotrd1
    Rate: 55
    [Film: 8c1d713b93] https://filmy.elektroda.pl/62_1484585302.mp4 [/ film: 8c1d713b93]
    Only today did the error appear again. I noticed that after this buzzing can be heard as if she would like to wash only she had nothing and the aqa stop valve will not drain
    Added after 49 [seconds]:
  • #7 16204602
    tod.1977
    Help: 65
    Rate: 149
    Hello. Take the solenoid from the housing and connect it to 230V and you will see if it works or not.
  • #8 16205144
    piotrd1
    Rate: 55
    Ie. when it comes to the aqa solenoid, it is all undigable, and as I wrote, sometimes it turns on and lets off the water today because from the 1 hour program half of the cycle runs about 32 min and only F15
  • #9 16208293
    piotrd1
    Rate: 55
    Today F02 error has joined, say repair or buy a new one?
    tod.1977
    Help: 65
    Rate: 149
    Hello. This indicates a solenoid valve, but there have been cases that a damaged heater gave such symptoms. If you feel strong, check the heater and solenoid valve.
  • #11 16216504
    piotrd1
    Rate: 55
    And a new one bought
The Hotpoint Ariston LFF8M121 CX EU dishwasher is experiencing issues where it does not take in water after a humming sound, accompanied by an F15 error code. Initial troubleshooting suggests a blocked or defective drain pump. The user noted intermittent operation where the machine sometimes pumps water but fails to complete the cycle, leading to the F15 error. Further investigation points to potential problems with the solenoid valve and possibly the heater, as a new F02 error has also appeared. The user is considering whether to repair the unit or purchase a new one.
